Question about Intel D865PERL Motherboard
D865 Intel Motherboard overheating
Despite the original Intel Fan, CPU overheating and alarm sounds when some tasks are executed and CPU use is over 50% for some minutes. If I don't stop the task, CPU turns off.
Someone could help me?
Thanks
Daniel
  • 2,418 Answers
The 50% useage of the CPU is the problem not a fan issue. You have a memory glitch or IRQ setting causing this. Go back to basics look for a Video problem or shared memeory - does this board have onboard video, does it have onboard audio, have you installed a add in video/audio card? Check your bios settings, look at shadow memeory useage.
Posted on Jul 24, 2009
Which Replacement Computer Fan is compatible
IF you are using Intel processor then I'll suggest you to go for Original Intel CPU fan and if you are using AMD processor then you go for Original AMD CPU fan
Aug 03, 2012 | Computers & Internet
Shuts down after few minutes
First check CPU Fan, most probably of not spinning in full swing, and turn off due to overheating of CPU. you can put one or two drop of machine oil into fan by removing upper part of sticker (intel original-case may be change according to Fan)
second check PSU, the power will went off if a PSU not supply power in required voltage.
vote me if found he;pfull.
Aug 06, 2011 | Asrock 775VM800 Motherboard
Compaq presario sr2172nx shuts down unexpectedly. Very loud fan. How do I adjust those settings in the BIOS?
The fan is probably heat-sensitive, and your computer is probably overheating, despite having the fan spinning at 100%.
Disconnect the AC power.
Remove the side-panel.
Using a can of compressed-air, give your motherboard & CPU & power-supply a "blow-job", to remove all the dust that has accumulated, and is acting like a blanket that is trapping the heat.
When your computer is running at a lower temperature, you won't need to adjust the BIOS-settings.
Aug 18, 2010 | HP Compaq Presario SR2172NX Refurbished...
Cpu in my coputer overheating to 65 c ,and blue screens appear and computer restart , what the reasons
Well your cpu is overheating. The cuase may be the cpu fan. So try to replace the cpu fan.
Regards, polysandy
May 19, 2010 | Intel Motherboard
Buzzer sound from intel d101ggc motherboard
Check the fans in your pc, it sounds like at least one of them isent working properly and your pc gets overheated. When a pc going to warm it gets really slow and hangs.
My guess is that the CPU-fan dosent work properly and your CPU gets overheated, but check all the fans to be sure. The CPU fan runs cantantly, check so it dosent stop now and then.
Good luck
Nov 21, 2008 | Intel D101GGC Motherboard
I need intel d865 motherboard drivers
download realtek AC'97 Audio driver from here
http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Nov 08, 2008 | Intel D845GVSR Motherboard
Problem with the CPU cooling fan...!! :-(
Dear ARGHYA,
welll i can understand this, for this you can apply the Heatsink Grease between CPU and CPUFAN . it will help to reduce the CPU Temprature.
Cheerup
Mar 04, 2008 | Computers & Internet
D865PERL Motherboard over heating
I had a problem with my P4 overheating on that same board, I cleaned all the dust out of the heat sink and the coolant fan, then also angled another fan at 45 degree from the back to the CPU sounds like alot, but worked for me.
probly just ganna be a hastle so unless you think a fan would help dont bother
Oct 20, 2007 | Intel D865PERL Motherboard
Intel original motherboard d845gvsr dead
it will be cheaper and more quickly solved if you just replace it go to computergeeks.com very goo site k
Sep 22, 2007 | Intel Motherboard
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Intel D865PERL Motherboard Logo
190 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
