SOURCE: trouble shooting radio wiring
Most always will either be a red or ornage wire for power and black or brown for ground. Use a test light to check those wires with the key off. If it lights up...main power/constant feed/memory feed. the ground wires will not light unless the clip end of the test light is attached to a power source
SOURCE: Need a wiring diagram for a Murry Rider, Model # 30575X8A.
Go to this web sight and enter your model number of your Murray.
http://www.murray.com/manuals/
SOURCE: We have a Husqvarna Rider, model YTH180. It's
whats rough the motor if so you could have bad gas or bad plugs or somethin els you may need to get that to a shop
SOURCE: MIDLAND 13-880B
The old Regency radios used a 'stereo' 1/4 plug (3 circuit). Back ring was ground, center ring was switch to PTT to ground and tip was audio line. Is your plug a 'stereo' 1/4 plug?
SOURCE: connecting the antenna wire to the radio
jojo says you could have pulled the radio and found the hole in as much time as it took you to log in and post thyis question.if you must know ,majority of radios the antanna plugs are located bottom right corner if you are looking at the face.
