Question about Campbell Hausfeld 04 Gallon Twin Stack Compressor HL5502
C.Hausfeld HLseries compressor pressure cut in setting
HiI have a Cambell Hausfeld HLseries compressor.....I want to set the cut in pressure (auto cut in) lower than the preset setting. This is to run it off my generator... the generator will power it, but struggles at first due to the start up pressure in the tank.....I opened the electrical housing and it looks like there are 2 screws that may do what i want....they are covered in a clear glue...i guess from the factory to keep the setting.....will these do it??
  • 10,865 Answers
Hello. The answer is yes. Let me warn you to make only small adjustments at a time and be sure to relock the two screws using some one minute clear epoxy.
Posted on Jul 24, 2009
Spray gun for cambell hausfeld model.#al2305-02..where can i get one
http://www.searspartsdirect.com/partsdirect/part-model/Campbell-hausfeld-Parts/Painting-equipment-Parts/Model-AL2305/0166/0733055
Dec 14, 2014 | Air Tools & Compressors
Cambell Hausfeld model wl506201aj compressor Hums when switched on
This could be caused by one of two things:
- a stuck or broke tank check valve. This would be evident if the compressor starts up when there is no pressure in the tanks but only hums when the tank pressure is up. Some valves can be cleaned and will work for a while but they usually have to be replaced.
- motor start capacitor. If the capacitor is bad it won't get the motor spinning, with or without pressure in the tanks. You can test it by taking the shroud off the pump and carefully bumping the motor to get it turning. Be careful, it may run up to full speed right away. If it runs replace the capacitor, if not you may have a burnt or shorted motor.
Apr 11, 2012 | Campbell Hausfeld Air Compressor Check...
Name: Campbell Hausfeld S/N: 0519588 Year: 1996 3.5 HP 11 Gallon Do you carry parts for the compressor described above ? In particular a Conrad Kit
No
This is not a business
It is a social web site,
we are at home
Use the Cambell Web site
You can buy directly from them
Mar 15, 2011 | Campbell Hausfeld NoEX8300 5HP 20GAL Hd...
Compressor will only build pressure to 75 lbs. and won't shut off.
hi! there, the setting of your pressure switch has the ability to control the cut in and cut out of your compressor.unplug the compressor check the pressure switch by opening the cover loosening the bolt nut at the top cover you can see the four set of contactor inside crack the contactor if disengaging to the other side there should be a disengaging of contactor to cut the power supply if defective replace,if it is functioning normally.if it is not defective set this to what you want operating pressure and observe the cut out pressure several times is needed follow the pressure switch adjustment procedure.have a nice day and fix my rate,thanks a lot.
Apr 20, 2010 | Campbell Hausfeld No.FP2028 Gal Pancake...
Air compressor's safety release valve pops open.
You need to replace the pop it valve with a preset on. they are cheap and readily available. You could adjust yours with a proper steup. But it may need new parts just replace it.
Nov 28, 2009 | Northstar Electric Stationary Air...
How do i set the cut in pressure on my CH HLseries compressor?
hi mate on the pressure switch you ned to undo the srew in the middle off the box then inside you will find a screw like this -<screw>+ turn it clockwise for more pressure and anti clockwise for lower pressur good luck
Jul 24, 2009 | Campbell Hausfeld 04 Gallon Twin Stack...
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 04 Gallon  Twin Stack Compressor HL5502 Logo
157 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
