Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Remote became unuseable. Tried system reset button numerous times. Currently unable to use front panel controls or remote to turn tv on.
    Problem Solver:
  • 6 Answers
Almost hate saying this but in your case it applies. Unplug the TV from power for a couple minutes and then plug it back in. Also on the remote itself make sure when you are pushing buttons the the "TV" button lights up indicating that the TV is the device being cotrolled. If that doesn't work go to the MFG's website and look for answers there 1st...hope that helps you!
Posted on Jul 24, 2009
I have an audiosonic km2120. This has recently been starting to not respond with both remote or buttons on TV. So is currently unusable. Any answers to this please?
In case of front panel buttons not working:
Check whether the Panel Lock function is activated. If this function is activated [ON]' panel buttons won't work. Check it. Refer its user manual for details.
In case of non-working remote control:
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 09, 2014 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Do i unlock the front panel lock on a RCA 27V55OT
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jul 09, 2012 | RCA 20F511T TV
PLEASE AM UNABLE TO TUNE MY T.V. TO A-B WITHOUT USING MY T.V REMOTE. I URGENTLY NEED HELP PLEASE.
Do your TV has a 'Menu" button on its front panel? If yes, you can enter its menu options, and select the inputs. If there is no such button, you must have a remote control to select inputs.
Jun 06, 2012 | Samsung Televison & Video
Hi it appears the IR sensor for my Toshiba has gone, it started intermittent then became unusable. To make matters worse I have locked the front keys as I have a baby who loves to press them. TV now...
i think that your remote control is faulty , change it because you cant unlocked your tv menu without remote control, check the battery and clean it properly
Nov 06, 2010 | Televison & Video
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Contro;
We will need to set the remote address again. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. If you have further issues let me know. Thanks for using Fix Ya.
Apr 04, 2009 | DISH Network IR Remote Control
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Channel locked
with the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
Apr 14, 2007 | RCA 27F530T 27" TV
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
