Question about Maytag Dryers
Upper cabinet on Maytag Neptune Model MCE8000AYW does not heat. Air flow is OK Lower tumble dryer does heat.
2 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Posted on Jan 29, 2009
MAYTAG NEPTUNE DC MOD# MCE8000AYW
Your exhaust is gettting restricted and not able to remove the moisture from the clothes. Also check lint screen with very slow flow of water. If water rolls off wash filter good .. If water can't pass through smoothly then air is also having problem being pulled through as well.
Nov 15, 2016 | Maytag Dryers
Control panel not lighting up
there is a fuse inside the machine but try to unplug it for 15 mins to reset and see what happens
Sep 15, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Model MCE8000AYW, Lower dryer section - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 14, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Dryers Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
