Question about Foxconn (865G7MC-ES) Motherboard
Foxconn Motherboards Led Boot display
My buddy has a Alienware with a Foxconn Motherboard in it. I'm not sure the model. When it boots up the LED code display says DA. I'm trying to figure out what that code means. Any help would be appreciated.
Not sure what the code means, but I got it once on a foxconn board when I accidentally plugged the ps/2 keyboard into the mouse port next to it.
Posted on Mar 15, 2008
  • 86 Answers
Without more detailed information, I really can't help you decipher that code... Since you don't know which specific Foxconn motherboard you're working with, it might be best if you contact Alienware Customer Support for detailed information:
Good luck; let us know what you learn...
Posted on Jan 27, 2008
Alienware area-51 7500 r4 powers up but will not post. LED on motherboard stays '--'.
It could be your power supply, memory, cpu or the motherboard.
Disconnect all USB devices connected to your PC with the exception of the keyboard and mouse, also if you have any devices other than the video card, disconnect the as well.
Try and see if your pc will boot now.
Try booting into safe mode.
Do you hear any error beeps?
Test the display on another pc to make sure it is working propertly.
I hope this helps.
Good luck and have a pleasent day.
May 17, 2011 | Computers & Internet
I have a foxconn motherboard (G33M02) and the LED is flashing orange and it will not power on. I have used the PSU on another computer and it work and when i used a different PSU the LED is steady orange...
 In that cse you must try 2 more things:
1 - remove all disks and try to boot in the BIOS - if it works then one of your disk is dead and blocks the motherboard. Find it by elimination and replace it. If it doesn't work then
2 - replace the memory, video card  and processor (in this order) and again try to boot in the BIOS. If everything fails then your mobo is dead, replace it.
Aug 11, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Connect power swithc and led cables to foxconn n15235
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Nov 10, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Wiring front panel
if you go to this website
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
Pc can't boot up , no display , hdd led is constatly lighted
Check CMOS battery(Coin shaped battery), it should show 2.5-3V, if not then replace and check, you can even try and test the mbd without the CMOS battery. Some mbd does not boot with a faulty CMOS battery.
Mar 17, 2009 | MSI K8MM-V Motherboard
Alienware Desktop will not boot
Try removing the RAM as well and see if it beeps...
Feb 11, 2009 | Intel D945GNT Motherboard
Startup fault
Software Error Or Corrupted windows File files
Jul 15, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Repeated boot.
ok... first check that all power cables from your supply are firmly in place and that the little red or green switch on the back of the computer that changes the Voltage setting is correct unless you have a UPS. secondly make sure no loose debry, cable, or cpu box it touching the motherboard and it is still secure in its mountings. then check that the power, reset and all LED plugs are correctly connected to your MB for connections look at your user book for details. now how far does the computer go in the POST ? if its possible i would also reset the BIOS by either removing the battery from the motherboard and starting it up then replacing it and downloading system BIOS chipset boot disk from: good luck.
Sep 19, 2007 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Foxconn (865G7MC-ES) Motherboard Logo
696 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
