SOURCE: 96 ford explorer code p0301 mis fire 1
Sounds like either a bad plug wire, or coil pack. This is about all that would cause the misfire.
SOURCE: craftsman weedwacker model 358.795160 will not
First, check the fuel lines for cracks/breaks.
If they are o.k.,
then you will need to disassemble the carburetor again. Make sure the small screen in the carb. is free of debris. You should be able to see daylight through it. Use
a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
SOURCE: My mini tiller has a Tecumseh TC200 engine. I can
If the crankshaft/flywheel alignment pin is sheared the firing will occur at the wrong time. Check that by removing the flywheel.
SOURCE: compression on 2000 polaris 250 trailblazer
the fuel could be good but still it wont spit check the carbs when you throttle or kick start if thats possible if that is good try some starting fluid it should start up and the fuel pump should get out the obstruction if theres more problems it is one of many things either bad fuel pump, your fuel line is disconnected, blown headgasket idk the psi specs for the 250 but that sounds good i know for the 550s its around 120 and so on
SOURCE: will not start - new fuel 50-1 mixture, checked
Will it start if you pull the plug and spray starting fluid in the chamber? if so then I'll bet you have a blown diaphragm in the carb or a plugged fuel filter or a bad gas line. hope this helps. Jeepfxr
