Question about Vizio VX37L Television
Message on screen "no signal input" with either HDMI inputs. Also get No signal from DVD player. Checked DVD and Sat receiver with another TV
Dvdr5520h DVD player HDMI connector problem
Hi S MArr
There are several input HDMI connectors and most often only one out put ---connector. Make sure you have connected your output HDMI to the TV/Projector and the DVD to one of the inputs and chose that input on your AV receiver ! Do not forget to turn on the DVD too. and give the Receiver and the TV some time to recognize and setup themselves to the signal.
Best of luck!
XyFinx
Jan 06, 2014 | Philips DVDR520H DVD Player/HDD
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
My problem is getting a "This signal is not supported message" on an HDMI input into a Pioneer PDPR05G media receiver.
No need to understand - just read the message, It clearly states that the unit will not accept that particular signal because its electronics are not configured to deal with it. And that is it - end of story.
Basically, you cannot force a square peg into a round hole.
Mar 13, 2017 | Pioneer Televison & Video
I have a LG47" tv
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Audio Players & Recorders
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Vizio VX37L Television Logo
201 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
