Question about GE WBSE2090A Top Load Washer
No warm water , only hot or cold
We replaced a hotwater heater a few days ago. During my wash cycles we are only able to get cold or hot water. The warm cycle will only put out cold water.What is the problem?
  • dos equis Feb 20, 2008
    GE Profile-7 years old. No warm water just Cold, Cold, & Hot
  • Anonymous Mar 27, 2014
    i have hot and cold water but no warm
  • GE Master
  • 5,568 Answers
There is a mixing valve normally located (and part of) the threaded connection for the hoses on the back of the machine.
These are junk when new and fail often.
The water heater replacement may have resulted in some ‘stuff’ getting into the lines and interfering with the mixer operation.
If one source is working and the other isn't, you may have screens at both ends of the water hoses and one end is clogged.
Removing the back panel is pretty easy and the valve is normally not tough to reach and often held in place by 1 or 2 screws only, with 1/4" or 3/8" heads.
If you have a Johnstone Supply in your area, the part will cost about half as much as from GE or Sears.
Posted on Jun 21, 2008
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
Washer will not fill up with water. but it will during rinse cycle
are u washing in hot
try filling with cold
did it work
if yes your problem is your hotwater solonoid either bad or stuck or clogged
Oct 09, 2009 | General Electric WBVH5200J Front Load...
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
Cold water problem
more than likely that your inlet valve is faulty it needs replacing thats the more common fault for water not going into the machine
May 29, 2007 | Fisher and Paykel GWL11 Top Load Washer
GE WBSE2090A Top Load Washer Logo
61 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
