Question about Cell Phones
Nokia n95 8gb .screen turned black.phone does not respond to any commands.changed battery still.Only for a few second blue light on buttons turn on.But again went dead.Any suggestion?
  • 1 more comment
  • angelhalo Jul 24, 2009
    That is bad news .Phone never got wet,I havent droped it.
    Why do the blue lights turned on for a few second?
    Is it to risky to open it and see if there is a loose cable somewhere?
    Any other idea for this to happen? Thanks ...Angel
    Any other ideas for this problem?
    Not Wet or dropped.Can someone fix it?
    thanks for your opinion.Im sad .it was a good phone.I wish there would be someone to fix it or send it back to nokia company but i dont know the address.Thank you very much....Angel
    President:
  • 846 Answers
Hello Angelhalo,
I'm sorry to hear about your misfortune. Basically this leads me to believe there is one or two possible problems with your cell phone.
Have you dropped the phone at all or got it wet ? These can cause the problem your having. If neither of these two things have happened the phone itself may just have been doomed to go defective before it even left the factory.
My other theory is that the connection between the battery terminals and the main circuit board are shorting OR one of the component's on the main circuit board is defective.
If this is the case then there is little you can do yourself unless you are an electronic and cell phone repair tech. The cost of paying a specialist to fix it typically is NOT cost effective compared to replacing the phone itself.
Post back with some answer's to my questions and I will promptly assist you further.
Thank you very much for choosing Fixya!
Posted on Jul 24, 2009
  • Quickfx PC Repair Jul 24, 2009
    Well the thing is,its a loose connection or a defective electrical circuit. The only other reason for this to happen is a manufacturing defect.Not your fault just bad luck getting a phone that was a ticking time bomb so to speak.
    Opening a cell phone can be done, you don't really have to worry about getting electrocuted or anything. Basically you could cause more damage than it has now, but at this point it almost does not matter.
    As I was saying earlier there is little that can be done. If it is just a loose wire and your Very skilled at soldering (if you got solder on anything other than that one tiny contact you would short it out even more). If its the circuit bored then you might as well fix it, do not worry about looking for a repair tech it will be more time consuming and costly then just replacing it.
    If you take the phone to a service providers store they should be able to recover any data that maybe on the phones internal memory ect. If you need it (just bring the old phone and ask them when you go to talk about getting it replaced). Make sure you bring it to the main store not like a mall kiosk or anything of that nature.
Wet phone black screen buttons light up can charge
Step one- try pressing volumen k- and power k at the same time .this will refresh your phone. Second possible solution. When your phone starts try hitting menu I before screen gets black and reset it.be aware this step erase all your stored info and contacts. I hope this will do something for your phone. Cheers:)
Dec 06, 2013 | ZTE Warp
Dark blue display on nokia 6110
dear just flash 6.2 ver.or chek sp data ur phone 100%ok
Aug 01, 2012 | Nokia 6110 Navigator Cell Phone
My Nokia 6790 won't turn on, what's wrong with it?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jun 20, 2017 | Nokia 6790 Surge Cell Phone
SOLUTION FOR NOKIA 7510 (won't turn on/flashing black and white screen) Remove the battery Press the power button for few seconds Install the battery back on Turn the phone back on it should work that...
I've had this happen twice, both times when I tried to quit during a long web page download. Just taking the battery out briefly won't help though. It has to be out for somewhere between 12 and 24 hours. Probably there's a capacitor or a small battery that has to drain in order to reset some volatile memory.
Mar 04, 2011 | Nokia 7510 Cell Phone
My nokia 7510 mobile isn't openeing it's just flashing (the screen) i wanna format it while it is closed,,how??
Remove the battery
it should work that how i did to my phone
Jan 03, 2011 | Nokia 7510 Cell Phone
Hi!...my nokia 7610 phone gotta a problem...it suddenly turned off and when i turn it on it continues to display nokia welcome screen.What to do fix this problem..???? plzzz help...
Your phone system problems, there is a way how to overcome them. Apanya you need to do a hard format, by way of pressing the keypads are numbered 3, the star (*) as well as with the call button. If this is difficult, ask someone to press the help button on / off. Wait a few seconds, until the screen was white, do not miss the on / off button. And if you find out the word 'format' on the screen. release the on / off button. from the left side of the screen you will find that the movement turns into a black screen. let it finish and your phone will restart. Note: Make sure battery at full charge and remove the memory card during this process.
Vote me if this is really helpful.
Jul 30, 2010 | Nokia 7610
Hi! My screen is white when turn on the phone. When I removed sim and memory card and turn on again, I see fabric black/gray background but can not see menu or any other commands.. Thanks in advance..
It seems to be a corrupted firmware. Nokia allows you to update the firmware over the net. How???
Fully charge the battery, backup the data on the phone, Connect the phone to the PC through a USB cable only. Start Nokia PCSuite and allow a few seconds for the suite to connect to the phone. It will display on the suite that Nokia 6300 is connected. Click on update firmware and follow instructions. When suite finishes, your phone would be as good as new. Restore the data to the phone.
For more info read the following link.
Updating the Phone Firmware (Nokia)
Dec 11, 2009 | Nokia 6300 Cellular Phone
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
