Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Mower won't start
I was mowing some thick grass one night with the deck on the 6th level. I wanted to get the grass a little shorter, so I moved the deck to the 4th level. As soon as I did so, the mower shut off. The next day, I tried to crank it. It clicks and has sort of a humming sound, but won't turnover and start. I have no clue what might be wrong with it. Checked the battery, fuel, and spark plug. All were in good shape. Any suggestions?
    President:
  • 1,124 Answers
How did you check the battery ?
It sounds like its a bit short of power to crank it over..
Try jumping it from a car battery..
Posted on Jul 24, 2009
My cub cadet riding mower is bogging down when grass gets a little thick
Inspect the under side of the deck for grass build up. You need to clean it about twice a year if you are mowing damp grass.
May 06, 2017 | Cub Cadet Garden
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
Strange noise from deck of Toro LX426
The engine wont have an impact with the deck because its belt driven. It sure sounds like you have a bad set of spindle bearings,just turning it by hand you wont hear any noise it has to be going fast to hear it. The noise may be coming from your clutch instead of the deck,and it sounds like the deck. Have these things checked out.
Aug 09, 2009 | Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
148 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
