Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Broken flywheel key
I have a 2002 murray riding mower 14.5hp briggs n straton. the problem is that when I go to start itit backfires and then I find that the flywheel key had broke. It happened 4 times so far. I had checked the timing on the crank and cam gears. they are fine.I had changed coil, spark plug,air filter,gas filter and it happened again. what else could I check?
  • 130 Answers
The slot on the flywheel and cranck might be worn check this allso check valve clearenc make sure flywheel is torque to spec.let me know want you find out.
Posted on Jul 24, 2009
I have a murray 20in. And it won't start its getting gas and firing what is wrong Murray 20in.push mower getting gas and fire but won't start
The kill switch may be mis adjusted. Sometimes the cable stretches and you need to adjust it or shorten the cable.
May 28, 2016 | Murray Garden
WHY FLYWEEL KEEPS SHERING THE KEY
Reset the ignition timing correctly before starting the engine.
Oct 13, 2014 | Garden
Morrow will not start just back fires
Backfire is a timing issue. The flywheel on those motors controls that timing. Check to be sure that the woodruff key is not missing and that the flywheel is lined up correctly.
Jun 27, 2014 | Briggs & Stratton Garden
12 hp briggs backfires doesn't start
This could be a result of several different things, however the most common of these would be a sheered flywheel key. If this is the case it has throwed the motor out of time and is trying to fire while the exhaust valve is open causing the backfire and lack of compression to start. I hope this has helped.
Sep 30, 2013 | Simplicity "Citation 61"" 28-HP Briggs And...
Briggs & stratton backfires & breaks flywheel key on starting
Be sure blades turning easy, one of spindel may have a bearing out or going out.
Nov 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Aug 14, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Briggs and straton 5 horsepower overhead valve lawnmower 1978 is backfiring through carborator
Remove the top engine cover and check that the aluminum flywheel key is not sheared, then remove the valve cover and ADJUST the 2 overhead valves. They have to be adjusted periodically on ALL small engines with overhead valves.
Aug 13, 2011 | Garden
I can't find any thing on my my riding mower
This machine was made by Murray who is no longer in business. Briggs and Stratton purchased a majority of the company and a lot of the parts can still be purchased through Briggs. I do not see a parts diagram for the (b) series but I was able to find one for an (a) which is a year older machine. I have included a link for the parts diagram of it. Murray 425614A Murray 42 Lawn Tractor 2002 Diagrams and Parts List...
Jul 14, 2010 | Briggs & Stratton Garden
Starter motor can't turn engine through compression stroke
valves are out of adjustment. reset them and it will do fine.
Apr 07, 2017 | Yard Machines Garden
Trouble with riding lawn mower
this sounds like a bent or broken key on the flywheel.this will cause it to be out of time.
May 24, 2009 | Briggs & Stratton 66set Panzer Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
765 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
