Question about Kenmore Washing Machines
Washer does not work. after it filled with water it quit and all I can get out of it is a humm.
    President:
  • 744 Answers
Hello, from the limited information I have this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupleing looks like: washer does not work. after it filled with water - 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector inbetween. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks! P.s don't forget to pull the plug on the machine :)
Posted on Jul 24, 2009
I have a frigid afire gallery series washer lights up and just humms, won't fill with water. I checked water pump and motor,not ether one of those humming
I WOULD CHECK MY WATER INLET VALVE, DO U HAVE WATER FROM THE HOUSE WATER OUTLET TO THE WASHER WORKING? NOTE" A BAD CONTROL BOARD CAN SEND A WRONG MESSAGE TO THE INLET VALVE? POSSIBLY IF NOT THE VALVE ITSELF, CHECK IT WITH A METER FOR CONTINUITY
May 13, 2014 | Frigidaire Washing Machines
No water flowing into drum, water supply is fine, just humms
My Samsung washer was not filling with water after cleaning the debris filter. All I did to fix it was to dump a half gallon of water into the tumbler, then I ran the beginning of the rinse cycle and it worked. It seems like the pump needed to be primed.
Sep 16, 2010 | Samsung WF337AA Front Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Maytag A9400 washer won't agitate
the motor, sorry! if left on wash cycle it humms for a bit quits and trys again? or not? the motor is about $130.00 part# 201805
Jun 30, 2009 | Maytag Washing Machines
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer does not fill with water
, did you try changing water temps switch to different settings, hot cold amd warm alll no good?? do you even hear a slight humm when trying to fill???, how about trying to put into spin cycle, does it do anything??? if you listen closly (put your ear to the timer knob assy)can oyu hear anything??? if not its quite oossible that you have a power issue, check your incoming power for 110 volts.
Mar 25, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
22 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
