The tv circuitboard has a 1\8 inch hole in it
The tv circuitboard has a 18 inch hole in it because something burned, is it fixable?
    Scholar:
  • 122 Answers
The board it self is probably toast but if the set is a newer model and expensive then it might be worth fixing with a new board. My rule of thumb is not to spend more then 50% of the replacement cost to repair. Try and get a rough estimate for free and decide if it is worth it. Good Luck
Posted on Jul 24, 2009
Why does my tv turn off by it's self after a few
Either a power board problem or something in the set is pulling the power voltages down---if under 26 inches it may not be fixable.
Mar 19, 2012 | Emerson Televison & Video
My 42" inch fried something
Ur tv still have picture,just have convergence problems wright?This tv is fixable,the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.Replaced all these parts on the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 16, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Sharp 26"hdtv started with a 1/16" color bar that
If you mean the bar goes top to bottom, there are circuitboards that feed the info in small sections top to bottom. But usually one section will be one inch wide. It can also be the screen panel itself. Try a trusted tv shop
Nov 25, 2010 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
I have a Speedaire model 3z492 air compressor. The manual is gone and the information plates as well. I need to know if this model is cappable of maintaining 100 psi @ 10cfm? Any ideas?
Here is info I found "Pump:
Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
Nov 08, 2009 | Air Tools & Compressors
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
Sep 04, 2009 | RCA 32V550T 32" TV
Hitachi 55 inch went black and standby light stays on
Hope you already resolve it, if not, here what I went through 1. go to http://www.service-docs2.com or similar place to get a service manual for your model ($10-18) 2. Open the back and follow instructions how to remove and test the SDR-D and SDR-U board on the far left (take one off, see if you could see half the picture). Inpsect the chips on those two boards, you might be able to spot the burned out holes (that would be the defected board, seemed to be a known issue for particular models) 3. If it is the board, go to ebay and get the pulled out board replacement ($70-90) I fixed my 50 inch plasma this way
Mar 21, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Top left corner double picture red and green
you have a failed IC resistor usually you can physically see the bad one because it burns out leaving you to guess what the value was. Hitachi offers a convergence fix kit which has 2 IC's and all approiate resistors.
Sep 01, 2008 | Hitachi 43FDX01B TV
Circuit board?
Please refer to the user manual, That is near the input power.
melnavz
Jul 28, 2008 | Smeg 18 in. STX45-1 Stainless Steel...
Televison & Video Logo
Top Televison & Video Experts
