I am looking for operator manuals for the following machines D3, D4E, D5H, 561 Pipelayers (Side...
(More)
I am looking for operator manuals for the following machines D3, D4E, D5H, 561 Pipelayers (Side Booms) At the top of your page it says manuals but there is no category for manuals, crawlers, sideboom, or pipelayers so I picked this one in hopes of someone "telling me where to go" thanks.
poulan pro 24hp 54in deck looses drive power on uphill grades like the clutch is slipping. Adjusted...
(More)
poulan pro 24hp 54in deck looses drive power on uphill grades like the clutch is slipping. Adjusted tension springs on hydro clutch with some temporary results, but always end up with the same problem. Ive found if I tighten springs to tight motor will not turn over.
cam and crank gear both have the timing dot on the gear tooth not one on the tooth and the other at...
(More)
cam and crank gear both have the timing dot on the gear tooth not one on the tooth and the other at the bottom of the opposite groove,is there another way to time this engine?
