Question about Dometic RM2652 Refrigerator
Refrigerator doesn't work in gas mode
Our Dometic refridgerator was working fine in gas mode a couple weeks ago, but now it won't. We've tried turning it on and off 3 times like the manual said in case there is air in the lines, and we checked to make sure there is gas in the tank which there is. We were able to light the pilot for the water heater. Any ideas?
Verify that you have gas at the pilot and that the spark ignitor is clean. Might be a good idea to get a vacum and clean that area out.
Posted on Jul 24, 2009
RM 2804 model, does it have a fuse?
under black cover in back possible heater element
Jul 14, 2012 | Dometic RM2652 Refrigerator
If I plug in my trailer and turn on the ref.model 2652 it works fine. I can convert it over to gas with no problem when it has been running off electric but if I try to light it on gas first it won't...
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Your problem seems to be in the control circuitry but I don't think it is a true fault. I would suspect corrosion on the connectors of the upper and lower control boards instead of a faulty control board.
I use a combination of scouring pad and #2 pencil eraser to clean the contacts.
Sep 06, 2011 | Dometic RM2652 Refrigerator
I have a dometic mod.2852 refridgerator/freezer that was working fine until a day ago when it stopped getting cold in both parts. It has power. the space between the freezer and refridgerator is very warm....
Check this link to dometic recalls first and enter your model number and serial number. There may be a recall on that fridge.
http://67.238.126.140/recall.php
Jun 13, 2011 | Dometic RM2852 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
May 26, 2009 | Dometic RM2652 Refrigerator
Unit will not turn onto AC
Heating element is burned out
Oct 20, 2008 | Dometic NDR 1292 Refrigerator
FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Aug 11, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
407 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
