Question about SanDisk MP3 & Digital Media Players
Play songs I have a SDMX1-1024 and no manual.I can not find the way to star any song
4 Suggested Answers
SOURCE: problem playing songs on SDMX1 1024R v2
Just a suggestion, make sure all your mp3s have been decoded the same and using cbr is probably your best bet. Your mp3s have got to be perfectly coded when using this player.
Posted on Aug 26, 2007
SOURCE: MP3 Player plays only 25 songs, capacity 1GB (861 MB)
Seems like a big problems you got there...
I reccomened re-formatting your drive to fat32 (for windows users) and giving it a second try.
I had the saem trouble a while back with my iPod Video 60gb and noticed that it was storing huge amounts of data that wasnt meant to be there. After the reformat it all worked again.
You also sure its not a full drive? because my Q-Be used to say "file error" on a full drive (vista bug)
---Give reformatting a go though.
Posted on Dec 11, 2007
SOURCE: zune 30GB plays songs at slow speed
Go to settings in the top right portion of the Zune software,
Click Device update, make sure it's up to date, then install games.
Darndest thing, but it worked for me. :)
Posted on Oct 23, 2008
SOURCE: iTouch replays same song over and over unless manually forward
Did end up fixing this by doing a reset of the settings on the iTouch. Working fine now.
Posted on Feb 03, 2009
0 characters
1 Points
Can you please tell me how to stop my Coby player from playing the same song over and over without my manually advancing to the next song? I must have selected a repeat option.
Are you playing files from a playlist, or are you selecting by Artist/Song?
If in a playlist, it should advance to the next song automatically. If you choose a particular song, it will just play that one song over and over. If you choose an Artist, it will play all the songs of that artist over and over.
Jul 12, 2011 | Coby MP707 MP3 Player
My ipod nano keeps playing the same song over and over, even on shuffle.
The shuffle setting is essentially random, which does _not_ mean that you won't hear the same song again until all other songs play. You might even hear the same song twice in a row, I suppose.
Are you hearing the same group of songs, and your other songs _never_ play?
If you scroll manually to a song that you haven't heard, and start play from there, does it revert to that same group songs, or play on to others?
All else failing, have you tried to restore your iPod?
Have you tried changing the playback settings in your iTunes preferences? You should be able to adjust the setting to make it _less_ likely for songs to repeat. I don't know how that would transfer to the iPod..
Hope this message can be fix to your ipod nano.
Feb 03, 2011 | Apple iPod nano
Loaded songs from cds ripped to computer. When itry ro play the songs on the media player, I get a 'format error'
Your getting a format error because the format of the song,video,etc
you are trying to play is not the format needed by your MP3 player to
play the song,video,etc.
Always check in your owners manual to find out what format your player
Once you have determined what the format you have (MP3,MP4,ACC,WMA,etc.)
you will need to determine what format you need for your player to play
those songs,video,etc.
If the format that you have for your songs,videos,etc is different than
the format that you need for your player to play them, then you will
have to download a format converter and convert each song,video,etc to
the format that is usable in your MP3 player.
Please rate me
You can download a FREE Media format converter at this website:
Jan 03, 2011 | MP3 & Digital Media Players
I can't drag and drop music from my library to the sansa clip. I have downloaded songs using Rhapsody and I can see where my device is but it wont allow me to drag my songs to it... I have purchased the...
Account Status
You need to connect to Rhapsody once every 30 days to continue playing your subscription tracks. When you reconnect, the 30 day license is renewed. The indicator will change from full circle to a quarter cycle as the days pass, and you will be warned when your tracks are about to expire.
Rate This Song
1. In playback mode, press the Submenu button.
2. Select Rate This Song.
3. Press |<< or >>| to change the rating (Negative to 5 Stars)
4. Select Negative to ban this track from playing again.
2. Select Purchase This Song.
3. When you connect the player to Rhapsody To Go, the track will be added to your Purchase Bin. You can decide if you would like to purchase it at your leisure.
Add To Library
2. Select Add Track to Library
3. A confirmation message, "Song has been added to your Library". Your song will now be a part of your device Library.
Artist Info
To display the artist information, press the center button 2 times when the song is playing back.
Account Info
1. From the Main Menu, select Settings.
2. Select Account Info.
Feb 26, 2010 | SanDisk Sansa Clip MP3 Player
Actions Mtp Device 000001 only plays parts of songs
At the top of the screen on the right hand side beneath the battery symbol and the song number there will be either a star, a 1, or an a in a circle, if there is a star, touch the screen until it displays the a in a circle, then it will play all of the song. If it is a 1 it will only play one song over and over again
Dec 03, 2009 | Actiontec DMP011000 MP3 Player
Rolly "motion" problem
well it depends on how long your song is, the Rolly manual says something like 3min max per song for motion, longer than that and the song plays normally.
May 31, 2009 | Sony Rolly SEP-30BTWHI MP3 Player
I want to play music continuously in my Thomson Mp3 Lyra 1GB
all you have to do is highlight all the songs you want to play. then you right click and click on play. it will automaticlly play your songs
Apr 16, 2009 | MP3 & Digital Media Players
Cant playing full songs.....
when you installed itunes did you check the box where it asked you to automatically eject ipod or manually eject?
Jul 25, 2008 | Apple iPod nano
How do I make a playlist on the player?
to make a playlist on the player, go to songs. When it displays all of your songs, scroll down to the one you want added to your mp3 player.Press the record button, quickly, and the music note next to the song will change to a star, I think its a star at least. On your mp3 player, it will be displayed as Favorites, not Playlist. Can you try to help me with my problem now/ Mine isn't working. THe subject is "How do I f/w update?" THanx so much!
Mar 21, 2007 | Samsung YP-U2X Digital Media Player
MP3 & Digital Media Players Logo
24 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
