Question about Kitchen Ranges
Range keeps shorting out. - Kitchen Ranges
  • acereno May 11, 2010
    need more info .....a hot wire is likley going to ground check all wireing for defects
Maytag gemini range
Don't keep resetting the breaker, you have a dead short and you could burn your house down, call an electrician.
Jul 22, 2016 | Maytag Gemini 30" Self-Cleaning...
Multimeters
Short Answer = YES.
Fluke 16 has a 4000mV range that can be entered only manualy. If you use auto range it will go to 4V as the lovest range but if you keep pressing range button you can go to 4000mV range with 1mV resolution.
Nov 14, 2012 | Fluke Networks Measuring Tools & Sensors
Why does my over the range microwave keeps shuttingoff our electricity in the kitchen
This may have a short in the high voltage side, rectifier or shorted high voltage capacitor. You may find it cheaper to replace the microwave, however you do need to call a repairman.
Aug 13, 2012 | Kenmore 1.7 cu. ft. Over the Range...
Kitchenaid gas range keeps beeping intermittantly, oven turns on by itself and code F2:E1 keeps comiong up on pad. What is the problem
Hi
Thanks for using FixYa. Error F2-E1 in your Kitchen Aid range indicates shorted keypad. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 29, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Fuse keeps blowing out on my 1995 range rover lwb every time I reconnect the battery it is the fuse for the fuel cap relay
It does appear you have a short circuit. Pck up an automatic circuit breaker at a parts store. Thy come in the style of plug that your fuse comes in and the proper amp rating. Put it in place of the fuse. It wil start clicking like a turn sigbal and give you a chance to find the short without having to keep changing fuses. If your fuse is a 20 amp, get a 15 amp so it will cycle faster. When you find the short, the breaker will stop clicking. Good Luck
_Ned_
Oct 17, 2009 | 1995 Land Rover Range Rover
Pilot keeps clicking even when burner operates;
unplug the range and wait 24 hours for the liquid to dry up. The clicking will stop when it is dry. The liquid has shorted the ignition switches causing the igniters to click.
Sep 26, 2009 | Tappan MGF500PBW Gas Kitchen Range
My GE profile gas range keeps clicking all the time, this happens right after we have cleaned the gas range. And usually it goes away after a few hours. But this time around it refuses to go and it is very...
You are getting water into the range when cleaning causing the igniter switch to short out. The reason why it goes away after a few hours is because the water finally dries up. When cleaning the range refrain from using so much water. You will need to leave the range unplugged until the water dries up again.
Sep 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I can't get my oven to go on, keep getting f-7 code on panel
F7
Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock
Apr 11, 2009 | Magic Chef CER3760 Electric Kitchen Range
I have a RSD30R Dacor range. I was given the range and no manual. 1. Can I get a manual on line? 2. When the Range was pluged up in keeps giving a beeping sound and flashing F1 HELP, I am lost!
Short of replacing the board, try to reboot it:
turn the breaker OFF and keep it OFF for at least 15+ min
(30 sec reboot does not work with this animal)
good luck: i hope you've fixed it long ago...
Jan 21, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Viking Range
Juliac, the burner valve switch for that burner is either shorted or grounding out. Each burner control has a valve switch that controls the power to the igniter. Sometimes they just get full of gunk and short. Part number is PA020015. Catriver...post back.
Nov 09, 2006 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
