Question about Cycling
There is a small plate between the rear derailer and the bike frame. Should this plate be on the inside of the frame? My chain recently got stuck between the frame and the gear sproket in the rear. I have another bike and there is not enough room for the chain to go between the space. It looks like there is some sort of spacer on that bike. I have an older Huffy Echo Canyon bike. I believe it is about 15 years old.
  • bb58248 Jul 25, 2009
    Sorry Joe, your answer is incorrect. I went to this site and looked at the manual before I tried the website. This manual is for coaster brake bikes, my bike does not have a coaster brake, it has hand brakes. I checked that manual as well, so don't recommend that one. Unfortunately, the manual does not get specifice enough in the instructions for assembly. Please try again or refer to someone who is more familiar with my specific Huffy bike for around that time era.
  • 339 Answers
Normally, the "plate" will be installed on the outside. It is also normal for there to be room for the chain to go between the sprocket and the frame although you of course don't want to have this happen. You need to adjust the limit screw on the derailleur to allow fulling shifting into the smallest sprocket without allowing the chain to jump off.
Posted on Jul 25, 2009
  • 10,865 Answers
Hi. I can help you. Here is the link to the manual that will answer your questions and assist you in properly placing the plate. It will ask you for the model # to be sure to provide you with the best info.
http://www.huffy.com/pdf/ownersmanuals/coasterbrake_manual.pdf
Posted on Jul 24, 2009
I bought a Schwinn Ditch 3.0 in a Goodwill store for $70.00. But is has problems with the rear derailer and the chain seems to be bent. What do you think it would cost me to have it repaired or replaced?
Take it to a bike shop for that. Labor is involved.
Web search things like "bent deraileur", "slipping chain" for an idea what the cause and solutions would be. Web search for the cost of 8-speed chains and rear derailleurs. The derailleur hanger itself could be bent. THAT is for a Bike Shop to deal with.
My guess is the total repair would be more than you paid for the bike but probably worth it.
Web search everything like "how to...". Lots of answers out there including videos.
http://bike-street.blogspot.com/2010/02/schwinn-mens-ditch-20-full-suspension.html
Aug 10, 2011 | Cycling
When I shift it's not smooth but the chain seems to jump all over , same thing happens when I put extra pressure on pedals
If it used to work and the cables are new then the cabels streached as normal you need derailer adjustments. If you have had it a while, and recently fell then you bent your derailer hanger take it to a bike shop to be straitened by a pro.. If it is a new bike and never worked at all then you need some derailer adjustments. You can adjust your derailer your self IF you know what you are doing. Otherwise go to a bike shop and have them do it. .
Jul 10, 2011 | Mongoose Cycling
Just bought a used mountain bike...chain keeps falling off
1) Replace the chain.
2) Adjust the travel of the front and rear derailer.
3) Make sure the rear wheel is set properly in the rear fork.
May 07, 2011 | Bike Extreme Lite Youth Shoulder Pad
GEARS ARE NOISEY , REAR SHIMANO DERAILER , FRONT GEARS HAVE BEEN AJUSTED RECENTLY
Could be either that your rear derailleur needs adjusting and/ or your chain has an issue such as needing lubrication or replacing.
Best to take into a bike shop and have them look at it.
Apr 08, 2011 | Cycling
Which rear derailer fit my trek bicycle
if its a newer style bike your are looking for a frame mount derailleur it has a single mounting screw laocated in the canter of the pivot these can also be specific to the amount of gears being used if its not frame mounted then its an axle mounted derailleur your looking for the are really cheap and are not specific to any amount of gears as the are not used past a 7 speed cluster in most cases if you attempt to replace this yourself you can have other problems arise if installed and the parameters are adjusted wrong leaving you with a chain stuck in the spokes or worse causing another derailleur failure i hope this helps u :) :)
Nov 16, 2010 | Cycling
Chain keeps coming off rear cogs when you stop pedaling, and when you change gears , Have had bike to bike mechanic twice to fix the problem to no avail ! Alignment of rear derailer has not solved the...
Coming off which side ? - outside toward the frame member or inside to the spokes.
You should avoid using the small chainring and small cog combination which is silly on the one hand, damaging to the drivetrain and usually results in a lot of slack chain dangling down between the derailleur and the cranks.
Here are instructions on how to set the limit screws which determine the physical end limits where the derailleur can lead the chain.
http://parktool.com/repair/readhowto.asp?id=64
Apr 07, 2010 | Cycling
Sticky chain
That is packing grease.......PB blaster or WD-40 spray will take care of your prob.
Mar 11, 2010 | Cycling
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
Schwinn S40 DSX part name
Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
May 30, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Cycling Logo
82 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
