Question about Jenn-Air JSD2789GEW Side by Side Refrigerator
Coil keeps freezing up
The coil keeps freezing up and refidge side gets warm. Is it the heater malfunctioning?
I disagree with the first solution. Although well intended, it is evidently for an older model. It leaves out a key part that can fail. It also incorrectly indicates that the defrost thermostat and defrost heater are two separate items (they are, in fact, a single assembly) Also, no specifications are given for testing this part.
I suggest proceeding as follows:
If there is a buzzing noise coming from the top of the refrigerator section (it will originate at the back rear corner looking into the refrigerator) the problem is a defective adaptive defrost board. You will need to remove the panels from top of the refrigerator in order to access this part. Replacements are available from most parts dealers and websites. Of course, you should unplug the refrigerator before starting this work. Once the replacement is completed, follow steps 1-4 below to remove ice accumulation from the evaporator coil.
If there is no buzzing sound from the refrigerator section, proceed as follows:
1. Unplug refrigerator.
2. Remove all wire baskets from the freezer section.
3. Remove the panels from the rear of the freezer section (two panels and four screws).
4. Use a hair drier to remove all accumulated ice and frost from the evaporator coil. Use a flashlight to verify that all frost has been removed. (Stop here and replace panels and baskets if you replaced the adaptive defrost board. Otherwise, proceed)
5. Unplug the defrost thermostat/heater assembly. Test the resistance of the thermostat with a multimeter. It should be around 240K ohms. Also, test the resistance of the heater. It should be around 20 ohms.
6. If the assembly fails either resistance test, it should be replaced. If both tests are passed, reconnect the thermostat/heater assembly and proceed.
7. Check the operation of the fan above the evaporator coil. This can be done by briefly running the refrigerator with the rear freezer panels removed. Observe the fan when the refrigerator starts (keep fingers away from the fan blades!). If the fan spins and circulates air, it is OK. Ifr not, it should be replaced.
8. If the fan and thermostat/heater check out OK, then it's back to replacing the adaptive defrost board. This board contains both mechanical and electronic components. The electronic components can fail without causing the buzzing noise described above. If the fan and thermostat/heater are OK, this board is the only other part that can cause this problem.
Posted on Feb 15, 2010
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! Mike
Posted on Jul 23, 2009
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Apr 22, 2012 | Frigidaire Refrigerators
What do you look for when your refriegerator/freezer does not get cold at all and the displayer in the front of the refriegerator signal blinks on freezer temp display
Check fridge compressor is working. If not replace relay. If working keep arm in condenser coil for warm. If no warm, no gas. Leak test and rectify. If warm and no whistling sound in freezer, system chocked. Release all gas and flush out system and replace filter drier. Vacuum and recharge gas. Check freezer thermostat setting is 5 degree. And also timer and heater are not malfunctioned.
thanks.
Feb 01, 2011 | Samsung RS2578BB Side by Side Refrigerator
I get a clicking noise but it wont get cold refidg. or fridg.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 26, 2010 | Kenmore 53662 / 53664 / 53669 Side by Side...
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
My Hotpoint fridge side by side freezer keeps defrosting too much. Mean it melts the ice and some of the food then it freezes again. I check the computer board in the back but didn't see anything wrong. I...
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Oct 12, 2009 | Hotpoint HSS25GFP Side by Side...
My freezer stops freezing and my refrigerator gets warm
everything defrosted in my freezer and now the refirerator is getting warm, here and there is sounds like something starts up and stops seconds later
Aug 14, 2009 | GE GSS20IEP Side by Side Refrigerator
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Magtag french door with water and ice despenser door with auto defrost keeps freezing up.
You have a defrost system problem related to the timing device, heaters, or defrost thermostat. Coils for the freezer are inside the back wall and defrosting the surface does not get ice out of coils.
it will not get any better until you have it serviced. This is not normally a project for a do-it your selfer.
May 28, 2008 | Refrigerators
Jenn-Air JSD2789GEW Side by Side Refrigerator Logo
716 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
