Question about Motorola Mobility RAZR V3
Screen flashes When i turn on my razr the screen shows hellomoto & sometimes flashes. Can this be fixed?
When I Turn My Phone On It Just Stays On The Hellomoto Screen.
Try powering up the phone without the memory card!!!chances are that the phone files may be corrupted the solution to this problem is to flash the phone!!
Feb 27, 2010 | Motorola Mobility RAZR V3
Frozen ''hellomoto'' screen on Razor V3c when turning on phone
You have a couple of options:
Take it to a motorola repairer or try to update the firmware on your phone. As you cant get it to go past the Hellomoto screen a hard reset would not possible.
Apr 05, 2009 | Motorola Mobility RAZR V3
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
I turn my motorola razr on and the hellomoto screen comes on and freezes what do i do?
the firmware needs to be flash back to the phone, take the phone to a mobile service center and have it done there...or you can try online at modmymoto.com
Dec 03, 2008 | Motorola Mobility RAZR V3
your firmware is corrupt, the only way to revive your phone is re flashing it.Its hard to do, and by doing it wrong may damage your phone. To safely retrieve your phone is let the experts do it or go to a near cell repair shop and let them help you out,
if you want to do it your self, try this
first you need is a RSD lite program or flash and back-up to flash or reformat your Motorola,
to enter the bootloader
hold * then the # then power button, your phone will boot to bootloader, and you will see there the flash program of your phone,
start the program rsd lite or flash and backup
then connect it to your computer VIA usb, automatically the program will detect your phone,
i prefer that you first buck up your firmware by using F&B (Flash and backup) then use RSD lite to flash your Motorola,
RSD lite its much easier to use than F&B, but for safety backup first your firmware,
gudluck
Nov 25, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Phone problem. Phone will turn on but...
Hangs on "Hellomoto"
Motorola Software Update (MSU) located on the Motorola website:
http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp
This should upgrade your phone’s software and restore functionality of the phone.
May 22, 2008 | Motorola Mobility RAZR V3
When turned phone on,the hellomoto comes on
and then to the BOOTLOADER blue screen. Means your phone has lost its firmware.. Take it to your SP and have them reflash it.
Mar 25, 2008 | Motorola Mobility RAZR V3
RAZR CELL PHONE FROZEN SCREEN
There might be a firmware issue, you might have to re-flash the software in it.
Nov 21, 2007 | Motorola Mobility RAZR V3
Blank screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
