Blinking clean light
remove the lower acess panel and there is a tech sheet / troubleshooting guide taped to te back side of it,, in there is detailed explaination of all your issues you may encounter with your machine.
I usually set to a test/diag mode and check to make sure your heater is working, after that if heater check ok youd want to listen for proper water amount being pump around interior of d/w(usually you can hear not really pumping with much force).
try pushing the sani-rinse. heated dry, sani-rinse, heated dry.. all lights should lite, indicating your in hte diag mode, it will then cycle through the tests afeter about 45 secs or so the motor will engage immedialty open the door assy and feel the heater coil for heat,if cold cancel test with the cancel button and try again.( i like to confirm the heater cycle twice),if you coil is still cold refer to the heat cycle test strip for repair.
aferer exiting hte test the clean light willnolonger be blinking regardles of repairing issue or not. perhaps it was a fluke happening youll be alble to run you unit, should it happen again immedialty youllnknow you a problem yoll need to adress
