Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
Sears 10 inch Radial Saw wont run
While using saw to rip a 2x6 blade stuck before i could shut it down damage done. The circuit breaker did not kick out neither did the reset on the saw motor. We had the capacitor checked but its fine. Any help will be appreciated . I have had the saw for more years than i can count. Richard
    President:
  • 1,996 Answers
Try blowing out the motor with compressed air, while rotating the blade by hand. (unplug it first.) Then press really hard on the reset, as sometimes they won't move much at all but will have popped. Use a center punch gently if you have to to push on it. If that doesn't yield results, I'd try spinning the blade by hand a bit and then pulling the start switch to turn the motor on. I once got one to crank up again by doing this, and it continued to work afterwards. (Be careful!) Seems like they are like old starters sometimes that get dead spots in the windings....
I know those are pretty basic ideas, but I have one I've managed to keep running for years as well, and would hate the thought of having to replace it... Also seems to me once I had to remove the cover from the motor and repair a shorted wire inside that was touching metal somehow. And that was only apparent after a similar jam of some sort, as I recall...
Best of luck and encouragement, anyway!
Posted on Jul 24, 2009
Hi, am looking for the 2 spacers and the neut that hods the blade on to a 10 inch craftsman radial arm saw and was curious if I could purchase one thank you
contact craftsman manufacturer spares to see if they are available
one washer will have a slot across the back and is the driving washer for the blade
the front washer will be flat and is the clamping washer
most manufacturers use generic products here so check for washers from other 10 " saws ( appliance repair shops , junk yard shops etc)
Sep 28, 2016 | Craftsman Radial Arm Saw W/ Stand 10 In....
Craftmans radial arm saw model 113.198111 short down within 3 to 4 seconds and pops circuit breaker
I purchased a Master Craft radial arm saw brand new and made three cuts and it did the same thing. I took it back to the store where I bought it and they gave me another new one. Something in the motor had burnt out.. You could smell it also.
Sep 09, 2014 | Craftsman Radial Arm Saw, Power Switch,...
Can you help me find a Source for Replacement leg for Craftsman part # 817105 Saw Model 113.198251?
Normally Sears is pretty good with older part . But if they do not have any go to a saw repair shop and see what they can do for you
May 17, 2014 | Craftsman Early 113.2xxxxx 10" Radial Arm...
Craftsman Sears Radial Arm Saw Rip Lock doesn't lock
Is the cam (815671) in place? Is it worn out? Check it.
Feb 28, 2014 | Craftsman Sears Radial Arm Saw Rip Lock...
Can't rotate Blade Angle for Craftsman Radial Arm Saw 113.23100.
The manual writer may have confused knobs or may have used different terminology to identify the same part. A call to Sears might clarify this issue, but then again maybe not. Check operation of all apparent knobs and you may locate the correct ones.
Dec 03, 2013 | Craftsman Sears Radial Arm Saw Owners...
While ripping 1x4's my 10 inch craftmens saw stopped running. Pushing in on the reset button doesn't help. After 2-3 minites saw will start up again. I'm not forcing the boards and overwor
the thermal motor relay is shutting it down,,motor to hot,
insure that all the air vents or saw housing are not full of saw dust. blow it out with air from a reversed hose on a shop vac if you don't have a compressor.
hope this helps.
Jan 03, 2018 | Craftsman 10" Table Saw
Need fence for radial arm saw
Most guys will attach a sacrificial particleboard sub top about 24" deep (per model) then towards the back of the saw attach a 3-4" square particle board rip, screw it down, then attach a 5/4 to 6/4 square maple fence approx. 4" tall and attach that to the 3-4" wide rip of particle board. then place a additional particleboard top in front of the maple fence. That will give you a 3-1/4" tall fence. all you would need to do is sqare it to the blade and attach it to the saw. Hope this helps
Nov 12, 2009 | Delta 10" Radial Arm Saw
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
432 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
