Question about Plumbing
Hi! Can not remove L-shaped linkage from overflow on old Kohler pop-up drain. Is there any way to do so without removing the pipes? Thank you
  • 297 Answers
Most times it just pulls off. some times it is secured with a screw check to see if there is a screw.
Posted on Jul 24, 2009
Kohler pop up plug staying closed
The plug has a little hole in the end - that rocker-arm lever fits through the hole. If the plug gets turned 90 degrees to the side before installing the lever, the lever won't go through the holeand the popup won't pop up. Pull the lever back out, rotate the plug 90 degrees with your fingertips or thumb, and put it back in. It may take several tries.
Feb 05, 2014 | Kohler Plumbing
Blocked kitchen drain
Due to pop up style drains they have mechanism in pipes and hair tends to wrap around it and over time it dangles down and slowly builds up blocks it. My tip would be to go underneath and unscrew it from basin and s bend pipe and just remove stuff from that point, just make sure you lay old towel in cabinet to catch all the water from pipe.
Sep 11, 2012 | Brasstech Lavatory Bathroom Pop-Up Drain -...
I have a lav sink where the stopper no longer comes up. The plunger shaft goes down. I have removed the stopper and can see that it has a female threaded "throat", but there's nothing to...
if you look under neath your vanity you will see where the plunger goes into the drain pipe. remove it and see if your activator rod is there, if so this is what screws into the plug end. if it is not there remove your U section and see if it is in there and reattach it. if it is broken you will have to get a repair kit at your local hardware store.
Aug 09, 2011 | Kohler 7129-A-CP Lavatory Grid Drain with...
How do you replace drives side exeior door handel for 95geoprizm
1) Remove the plug inside the interior armrest and remove phillips screw.
2) Remove armrest and two screws that hold door panel to door frame.
3) Pop the outer cover off the interior door handle.
4) Remove the interior lock knob and remove door panel by popping out tabs connected to door frame and lifting up off of window ledge.
5) Remove the two nuts holding exterior handle in place.
6) Disconnect the L shaped linkage from the handle. The trick to getting the L shaped linkage into the new handle is to feed L shaped metal pole through hole in door where exterior handle was, leaving the lower end of this linkage in its slot.
7) Feed the end of L shaped pole through the plastic 'hinge' in new handle by folding the hinge over and pushing the end of the L through both sides of the plastic hinge at once. slide the lower loop of the plastic hinge down the L shaped pole to secure pole to handle.
8) Place new handle into door and reverse the process to reinstall interior panel.
Hope this helps Tim
Apr 17, 2011 | 1995 Geo Prizm
I am trying to use a plunger in a slow drain. bathroom lav. The pop-up valve stopper is in the way of my plunger. the Pop-up valve is a Price- Pfister. My past experience with other older pop-up valves has...
Some of the drain plugs have holes or slots in them so that the stopper can not be removed without taking the actulating lever out from under the sink. This rod is part of the linkage that is hooked to lift rod on top, Unscrew retaining nut to remove rod so you can take stopper out. Remember that any water that is in sink is going to run out of this hole once you remove rod. Good luck and thank you.
Feb 21, 2011 | Price Pfister 47 Series, Lavatory Drain...
Drain won't move up or down on kohler whirlpool tub
I gather it is a lever handle drain if so you need to remove the plate and linkage at the overflow to clean up the parts and spray it with WD40 or silicone spray and reinstall
Nov 22, 2009 | Plumbing
I have a price fister BATH faucet set installed on an old bathtub> i would like to remove the knob that actuates the stopper mechanism. it is slightly triangular in shape and it does not seem to be a...
You will have to change out the waste and overflow. This is not a hard job, unscrew drain from tub, remove overflow plate and disconnect from p-trap. Go to local home improvement store and buy a new waste and overflow kit, many to choose from. Reinstall .
Oct 03, 2009 | Geberit Bath Waste and Overflow Tub Drain...
I am trying to remove the pop-up drain
To clean the drain simply remove the packing nut off the back of the pop-up assembly. This is located under the sink itself and will be on the back side of the chrome (might be plastic) pipe coming out of the drain hole. This nut is what is holding the rod in place. When you remove it be sure not to lose the ferule (nylon washer) inside. after the nut is off, you can pull the actual stopper out and have better access to the drain inside. Use a small hair remover (you can buy these at the "depot"), it has a long body with small "spines" coming off the sides to catch hair, to pull out hair. It should be long enough to get into the P-Trap. After you are satisfied you can put the stopper back in. Make sure the hole in the bottom of the stopper is lined up to catch the rod. Reassemble the packing nut with ferule and check for leaks. If you want to take the trap off be sure to have some 'pipe dope' on hand to reseal the threads. Teflon tape is not necessary. Reassemble the trap and check for leaks and you should be good to go. Good luck :).
Mar 21, 2009 | Home
Initial set up WMA 30
Hey mike mate problem with the washing machine is minor, however your gonna have to get the top off the machine to get to it.
It seems to me that the plastic tubing connected to the pressure swtich has come away. OR is damaged leaking air. However it is common for it to come off in delivery especially when its an old machine and has no transit brackets.
Theres only two screws to undue, their near the front on either side of the machine.. located behind two oblong caps. remove caps remove screws and push the top back and off.. the swtich is directly behind the soap draw. it has two single wires and two wires on a plug attached.. DONT REMOVE THESE.
THE PRESSURE SWTICH COMES IN TWO SHAPES EITHER ROUND OR OBLONG BOTH HAS A LITTLE TUBE STICKING OUT THE BOTTOM..
Check to see if a plastic tube is connected to it and running down to the filter compartment. most likey it aint hence causing it to overflow..
Dec 22, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Plumbing Logo
90 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
