SOURCE: ACCESS?!?!?!
I had to tap the entire front of the lense on the fat part of my palm. I had to do it 4 times semi-hard. Then the camera just popped on. Thanks for the tip, I did have to do it three times turning it off and on after each 4 strikes. The fifth time was a charm. I now have to do it every time to make my camera work. Crazy but it works.
SOURCE: system fan has failed
When the system fan or cpu fan fails you will get this message, or sometimes the computer will actually start, but then shut itself down. The only way to fix this problem is to replace the failed or failing fan. If you don't know how to replace a fan inside a computer, then I highly reccomend that you hire someone to replace it, or get a friend who knows what they are doing, to replace it.
SOURCE: Hi, I deleted some files by mistake on an ols ACER
Turn computer off then restart Keep Pressing F8 over and over then open up on Safe Mode and try to Fix problem.
SOURCE: Acer Veriton m460 keeps rebooting running windows
try booting in safe mode. then scan for possible virus. then restart and login in (not in safe mode). if it still wont work, reformat the drive then do the fresh installation of windows.
SOURCE: 1999 Silverado message center flashes security,
possible short in ignition switch or cluster panel
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
