Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Our Maytag MDBH950AWS is only two days old and we are having the
Same problem. It remains full of moisture even after the heated drying cycle is complete. Where does it vent? There aren't any steam vents up front! I called the company and was told that after three months, the machine will have adjusted and the moisture will not occur.
I have one that does not vent. Was told the new one do not vent. Mine is 1 month old I have had repairman out twice. #1 Said my heater worked. #2 said he repaired my venting that was blocked.No steam in front anymore.
The problem with the dishwasher being full of moisture after the drying cycle, also letting it stand overnight after drying, STILL full of moisture! I think this is going to remain like this. After three months is it the machine adjusting to the moisture or YOU!
Posted on Sep 07, 2009
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Jun 21, 2015 | Viking Dishwashers
It wont start. the hi temp and heavy button are the only buttons that come on
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Hopefully some of that helps!
Jul 08, 2012 | Maytag 24 in. MDBH950AWS Built-in...
My daughters Maytag Atlantis electric dryer model# MDE7400AY has just warm heat, taking an hour to damp dry towels, and there is NO lint in trap. Checked to make sure exhaust pipe is not clogged, and found...
cleaning the vent is always a good thing, But check the outside vent cover, some of them have a flap inside that sometimes get clogged with lint especially if damp, The only way for moisture to leave a dryer is to have a clear shot for the heat to escape , thats all done through the vent, if it has moisture in it, something is blocking its escape
Jul 13, 2011 | Maytag Dryers
I have a Maytag Legacy Electric Dryer Model MED5570tq0. It turns, gets heat, but does not dry the clothes. It would take 2-3 cycles to dry clothes. Any suggestions?
Hi jamesholl456...
Sounds like you have a Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Apr 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
My maytag neptune dryer is taking twice as long to dry cloths. i've had it 5 years & it's gas.
Clogged Vent
Cycling thermostat
This is a free answer, Please rate me.
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Heating element stays on after cycle has completed. Goes off when door is open. Maytag MODEL MDB5601.
It is possible that the relay is actuated from the control board and gets disconnected only when the safety swtich is engaged- when you open the door. hence you will need to check into the circuit to trace, from the heater to the driver relay. Checck if there is a short or a false trigger. This may be a bit difficult as the PCB- printed circuit board - may be filled with epoxy to prevent moisture build up and testing could be difficult. Normally the companies recommend board change but you need to check if familiar or get help to probe into this switch on. Hope you try this out. Good day
Aug 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
I have a maytag dishwasher and the light wash light stays on even after a wash cycle. Tried to press normal wash and goes back to light wash. What could be wrong?
Buttons could be shorting out and not makeing proper contact from just being old,How old is you unit?? Alway put age with your question,,on anything! Nobody wants to beleive there unit is old,Humane nature I guess, Always keep manual with purchase date in it handy.If it lasted more than 5 years your very lucky.specially if you use it everyday.
May 15, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dryer won't shut off automatically
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
Maytag dishwasher Model MDB9150AWQ won't unlock
try this keystroke..."high temp wash" "heated dry" "high temp wash" "heated dry"
Apr 17, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
220 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
