Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Cleaner puts out water/ solution, but won't pick up.
    Problem Solver:
  • 8 Answers
Go to bissell.com also check your belt
Posted on Jul 27, 2009
I borrowed my friends Hoover carpet cleaner and cannot figure out which side the shampoo goes in. Model #F6213-910
Put water in one side (just pick one), if it doesn't spray on the carpet it is the other tank you need to fill with cleaner.
Feb 16, 2017 | Hoover Vacuums
Hoover f8100900 will not suction
Here is a site which will guide you through possible causes that are causing the problem with your vacuum and help you pin point the correct one. Hope this helps. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Vacuum-Cleaner/113-203--/Hoover-Vacuum-cleaner-won-t-pick-up-no-suction
Jan 12, 2018 | Hoover F8100900 Upright WetDry Vacuum
My pet wash bissell shampoor won't pick up the water
Hey Deanne!I know how frustrating it is not having suction when you need it.
Here's a quick link to troubleshooting steps to assist you with the suction.
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 23, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Changed hose on carpet cleaner and it wont pick up the water
If you are unable to pick up water from the carpet after using the hose attachment, is is usually due to one of two reasons.
1 - The duct on the front of the dirty water tank has not been put back in place after using the hose. It is a square plastic piece about the size of a slice of sandwich bread.
2 - The lid is not properly seated on the tank. Be sure to hook the two tabs on the front edge in place before hooking the latch at the rear. This also applies when using the hose.
Feb 19, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
Apr 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover model F8515 won' t **** up any water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=703954
Hoover Model F8515 won' t **** up any water
posted by kevingao92 on Jun 24, 2008
It could be in reverse do you have any tips
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Model # F8515 works on the pull back to pickup the water and on the push forward you can dispense extra water or solution and the brushes will still scrub but on the pull back it dispenses, scrubs and also picks up the water all in one sweep, if not then contact you local vacuum dealer in your area, check the owner’s manual for the trouble shooting guide and or call the Hoover Factory cust serv @ the information listed below.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Won't **** up water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=554095
Generic problem for all Vacuums
Won't **** up water
Posted by fusco7 on Apr 28, 2008
Won’t **** up water
We need more information like the brand name and model number to try to describe why it won’t pick up water, could be a clog, could be that the gasket is shot, the tank may not be sitting the vacuum correctly, and by giving the brand name I can direct you to the correct vacuum cleaner dealer or factory manufacturer so you can get this fixed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
207 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
