Question about Panasonic PT-52LCX66 Projection Television
52lcx66 malfunctioning Yesterday my tv was working fine. I came home from work today and now I cannot do anything with my tv except turn it on and off. It does get a picture. I have a 360, dvd player, sound system, and digital cable hooked up to it. It was last set to recieve the cablebox. It was turned off and i went to bed. I tried to play my 360 when i got home from work and the only thing that i was able to do was turn the tv on and off, both on the tv and with the remote. I turned on the cable box (with my panasonic remote) and that works fine. Any help would be appreciated because i cant afford to buy a new tv at this time.
  • marklar1313 Jul 24, 2009
    I fixed my own problem. I unplugged the tv for an hour and then plugged it back in. The tv and remote worked fine after that. I'll update if the problem happens again anytime soon.
  • 192 Answers
SOURCE: PT-43LC14 No Picture, chirping sound when turned on
Begfore calling a servicer, pull the bulb out and check if it is broken. The chirping you hear could be the ballast trying to fire the lamp. If it is blown, make sure you clean the vent filters when replacing it.
Posted on Dec 12, 2006
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
SOURCE: Panasonic TV not working
Sounds to me like your convergence chips could be gone
Posted on Jun 21, 2008
SOURCE: Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Posted on Aug 07, 2008
Www sanyoctv com
Refurbished needs to be refurbished
Aug 22, 2014 | Sanyo 26" Class LCD 720p 60Hz HDTV and DVD...
Honda pressure washer 2400 psi worked fine yesterday, today the pressure is low, seems to work fine except the level of press sure is low any suggestions?
Check for an inline filter on the water hose connection, the low pressure side. Depending on your water quality and if any spiders made homes inside your hose, they can get clogged pretty easily.
Jun 07, 2011 | Garden
Soound but no picture
Disconnect the A/V cables from the TV and the system and then reconnect them this should work.
Apr 26, 2010 | Sony PlayStation 2 Slimline Console
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
It's been working fine..No problems...Came home yesterday and TV wont turn on..Power hook is fine.No luck with remote or the power button the T.V...No sound, no anything !
It may be the power supply board in the TV. It most likely isn't any type of fuse, which is the popular belief in situations like yours. If you're in warranty, the repair will be covered. If you're not, you'll likely have to come out of pocket to get the TV fixed.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 02, 2009 | Televison & Video
Exactly same problem just happened today! Only power button on the TV set and remote control works, no sound
I had this problem happen to me today. What i did was unplug the tv for an hour and when i plugged it back in, the first time setup appeared on the tv. The remote and the tv buttons worked fine after that. Hopefully that works for you too.
Jun 06, 2009 | Panasonic PT-52LCX66 Projection Television
Three colors are not together
Convergence problem needs two ic 's to fix.
May 25, 2008 | Philips 55PP9401 55" Rear Projection...
Speaker Test
Micro-processor malfunction. Take to pro/tech
Feb 23, 2008 | RCA RT2360 System
My tv is on but the screen is black except for spuratic flashes
i have the same problem, yesterday my tv stops, today I was on the internet trying to find something , I find a Phone number so you can call and explain what is your problem . It works. 1 800 726-4405 or a web page akaiusa.com try it.
Jul 05, 2007 | iLO V27DMBX Television
Panasonic PT-52LCX66 Projection Television Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
