The G2 Stitch series on the Bernina 1530 Inspiration is a set of decorative stitches that are programmed into the machine's memory. To access these stitches, follow these steps:
1. Turn on your Bernina 1530 Inspiration sewing machine. 2. Use the stitch selector dial or buttons to select stitch number 800, which is the starting point for the G2 Stitch series. 3. Once you've selected stitch number 800, you can use the stitch length and width adjustment dials or buttons to customize the stitch to your desired specifications. 4. To access the other G2 stitches, simply press the "next" or "previous" button on the stitch selector panel to cycle through the stitch numbers. The G2 stitches are numbered 801 through 811. 5. Select the G2 stitch you want to use, adjust the stitch length and width as desired, and start sewing!
It's important to note that the G2 Stitch series is not available on all models of the Bernina 1530 Inspiration, so if you're having trouble accessing these stitches, it's possible that your machine may not have them. In that case, you can consult your machine's manual or contact a Bernina dealer for assistance.
Since every machine is a bit different, you will just have to experiment. An 1/8th stitch length means there are 8 stitches to an inch. So measure an inch and keep adjusting your stitch length until you get 8 stitches to an inch.
Does your Bernina have the basting stitch? Could be the basting stitch mechanism has hung up (common for the Berninas from this era). A Bernina technician can fix that for you.
Stitch length @ 2.5mm (between 2 and 3 on the scale).
Stitch width @ zero.
Top selector lever @ 1 / 2 or (1 slash 2).
Needle position @ center.
That's it, no rocket science here. Stitch length will vary per application and per user choice. The 2.5 setting is only a suggested default.
If you have a drop feed mechanism make sure you have not dropped the teeth down by mistake, make sure you have enough pressure on the foot, remember you should not be able to pull the fabric through by hand if the teeth are up
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
