Question about Xerox Office Equipment & Supplies
Black streaks in copy. i have cleaned the drum and replaced the toner cartridge. anything else to try for this older xe80/xe82
  • Xerox Master
  • 6,696 Answers
You cleaning blade for the drum may be needing replacement, mite have some harden toner on the cleaning blade alowing toner to run around the bad/hard toner leaving streaks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 24, 2009
My copies have streaks of black on them. Do I need to replace the toner?
Maybe, what kind of Canon is it? You may have a cartridge with the toner & the drum? Or you may need to have the drum unit replaced O the drum & cleaning blade replaced or you need to clean the adf slip glass
Sep 26, 2010 | Canon Office Equipment & Supplies
What could cause wide black streaks when I try to make a copy? I cleaned the tranfer corotron, but still have the streaks. No warning lights come on for toner or drum cartridge replacement.
you may see the drum surface if there are black line left. if there is then you're having a problem with your drum unit; most probably the cleaning blade of the drum. :)
what is the model number of your machine anyway?
Mar 23, 2010 | Xerox 8830 Copier
THERE ARE LARGE STREAKS OF INK ON ALL COPIES AND
The green roller is the drum which has a cleaning blade to remove excess toner, when the drum gets older it becomes clogged and will dump toner back out onto the drum. Just some info on it. Best fix is replace the drum, you could take it apart and attempt to dump and clean it but it's rarely worth doing that.
Jan 04, 2010 | Brother IntelliFAX 4100 Laser Fax
I have a PC 25 copier. I am getting black streaks
Run a copy and shut the machine off when the copy is half way through. Open the machine up and remove the toner cartridge. Turn it over and slide open the flap that covers the drum. If you see toner streaks on the drum surface similar to what you see on the page you have a defective toner cartridge. Most likely the toner you bought is remanufactured as this machine is very old. Maybe you can return it for another.
Oct 18, 2009 | Canon Office Equipment & Supplies
Streaking copies
Have you changed the drum unit recently or emptied out the waste toner in the drum unit? If not try to empty the waste toner and clean the area that is right under the drum unit... * Note* do not wear any thing white... Toner can make a vey big mess...
Jan 26, 2009 | Office Equipment & Supplies
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
I have an HP3800n printer. Ever since I cleared a jam copies of jobs come out with streaks in the background and smeared lettering. Any suggestions?
You have either dirtied or damaged the drum and/or toner in some way while cleaning the jam. I would first try removing the toner cartridge, open it, and while turning the gear on the side wipe any black toner from the glass surface. If that doesn't fix it, replace the toner cartridge entirely. If it still is resolved you will need to clean or replace the drum.
Dec 09, 2008 | Office Equipment & Supplies
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xe80 copies coming out almost black on auto or light
Hello sir; Just replace drum cartridge it will take care your problem, GOOD LUCK!
Oct 30, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Aug 22, 2007 | Brother HL 1440 Laser Printer
371 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
