Question about Canon PowerShot A75 Digital Camera
Computer will not recognise camera.
Hi, when i plug my camera into my pc, running windows xp it says "usb devise not recognized". I have tried different usb ports and it has worked previously but has now stopped working. i've tried downloading and installing the the driver but it still doesn't work, can you suggest a fix please?
  • 6 more comments
  • Anonymous Nov 22, 2007
    After downloading thousands of photos, one day, my computer would not recognize my camer via usb. I have tried installing and re-installing drivers. In addition, a couple of registry hacks, still no luck.
  • tjchiro3 Nov 23, 2007
    exactly the same problem as above
  • Anonymous Nov 29, 2007
    Same as above. What to do?
  • Anonymous Dec 06, 2007
    Exactly as the others...
  • cannonman Dec 15, 2007
    Same problem. Dmped 1100"s pictures to an XP machne and OS X with no problems then yesterday, after being recognized (on the Mac) and previewing all the pictures, when I hit Download it said no camera. I then immediately tried it on the XP box and "no camera". Just like flipping off a switch, it hasn't worked since.
    It still plays through the composite cable to a TV.
  • Lilswifty28 Feb 10, 2008
    Same problem... still havent been able to find a solution.
  • Anonymous Mar 22, 2008
    USB connection all of the sudden completely dead. Nothing works, PictBridge dead, too. I assume, some bad chip Canon used...
  • Anonymous Mar 24, 2008
    same as the others
Same problem with SD700.
Posted on Dec 19, 2007
Computer does not recognize it
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
good luck
Aug 03, 2009 | Magellan Maestro 4040 GPS Receiver
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Mar 26, 2009 | Canon EOS 450D Digital Camera
Capture video not responding - driver issue
Hi All,
This problem is sorted out, upon checking the handycam the USB streaming was not enabled, the same was enabled and my computer could recognise the device.
Dec 26, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
My computer doesn't recognise my camera.
Hi There, If you are using Windows xp or vista, you probably don't need special drivers, the computer should recognize what you are trying to do. Just in case, check your owners manual for computer/download info. Also check your usb input or try another usb input to make sure they are working. You could also try a friends computer to eliminate trouble with your own. If all else fails, you could purchase a usb multi- card reader to down load your pics, around $20.00.
mr cicmo
Dec 25, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Gateway Pen Drive .... not recognized on Windows XP
@Enquiry: It's a USB 2.0 pen drive, which might not backwards support USB 1.1 without drivers. Many computers have USB 1.1 out one end of the case (back) and USB 2.0 out another (front).
Nov 22, 2008 | Gateway M275 Tablet PC
My USB device is not recognised
try to plug it to a fresh windows xp. install your driver and i think that would be recognizable by your computer. i had the same problem just like yours with my computer but after i format my pc and installed a new windows xp service pack 2 with other drivers, it is now detectable. hope that helps!
Jul 28, 2008 | Sony Handycam DCR-TRV17E Mini DV Digital...
Camera and scanner no longer recognised
On Windows 2000, XP, and Vista, you can get to Device Manager by right clicking on your desktop's "My Computer" (or "Computer" for Vista) and select "Properties". Then click the "Hardware" tab. Then click the "Device Manager" button (Vista may be slightly different).
As for why they are recognized on your friend's laptop but not yours, it's going to depend on what operating systems both are running and what the brand/models of the camera and scanner are. If there are drivers required to run the camera and scanner, try uninstalling and reinstalling them.
Mar 04, 2008 | Computers & Internet
When I plug in the HDD16 into the USB my computer says devise is not recognised
Please clean the usb cable. Use a cotton swab with Alcohol on it. (Not dripping). You may need to use a few. If that fails to help, try another usb device in your PC & check if the PC can see that device. The cable could be defective. The FAT on the drive could have been damaged or the drives file system could be corrupt. The usb port could be loose from plugging in & out. If your OS is Vista that can be the problem. Try a Pc running XP.
Please check these links for more options. Try this as well.
Post back & we'll go from there!
please vote after everything...
Feb 07, 2008 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
have you tryed to plug camera into another computer, maybe a windows?
have you tryed to use another usb cable?
also connector in camera can have bad soldering
check this movie
hope this help you get closer to solution
;) /michael
why pay when you can play
Dec 19, 2007 | Cameras
Canon PowerShot A75 Digital Camera Logo
80 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
