Question about Sony VAIO VGN-AR630E Notebook
Sony VGN AR630
LCD Lid has about a quarter inch of slack in it, how to tighten?
  • Sony Master
  • 32,281 Answers
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Posted on Jul 24, 2009
Replace tension pulley need speck
You need "spec". Just replace pulley, then pull it as tight as you can. after that, there should be no more than 1/4" slack in the pulley. In other words, try to bend the belt with your finger. Does it push out of line more than a quarter of an inch? If so, tighten it up.
Feb 03, 2015 | Plymouth Voyager Cars & Trucks
How do I replace a belt on Model no. 110.67032600
The best way to get the correct length belt is to use a piece of string, wrap it around the pulleys. Then measure the string, subtract about an inch to an inch and a quarter. Take that measurement to your parts supply store. By subtracting that sum it will give you good belt tension.
Dec 30, 2014 | Kenmore Elite HE4 Electric Dryer
Seems to petal to hard ??
Easy answer? Check you tire inflation.
More complex? It could be a number of things starting with your chain too tight. Have someone hold the back of the bike up and turn the crank to see if it turns easy. Take note of the chain; at some point when turning slowly you should see it/feel it loosen. If it seems really tight undo your rear axle bolts and adjust the chain so it has about a quarter inch of slack. Make sure that the wheel is centered before you tighten the bolts back down.
This also could be a problem: the back wheel wasn't secure and it is rubbing on the frame. Center the tire between the frame and tighten the bolts.
If all that is OK then it could be bad or over tight bearings.Then it is really bike shop time.
Mar 19, 2013 | Huffy 26 in. Cranbrook Cruiser Bike
Horizontal,wavy lines on sony xbr4 46" sony lcd tv
Disassemble rear panel, check all ground wires and connectors.
UNPLUG TELEVISION. While off, reseat every connector you can find on the back of the unit (unplug and plug in one at a time every single jack/cable connector you can see).
PLUG IN TELEVISION. With power on, carefully loosen (one quarter to 3/4 turn should do it) and then tighten every screw which has a cable attached to it (ground screws) and see if that fixes the picture as you are tightening the screws.
BE CAREFUL AND DO NOT TOUCH ANY OTHER PART OF THE TV WITH THE SCREW DRIVER WHILE YOU ARE TOUCHING SCREWS. Could electrocute yourself.
I had a similar issue as well as blotchy screen and this appeared to have resolved the issues.
Feb 26, 2013 | Televison & Video
Sony vaio vgn-ar730e/b lcd is loose
Remove the strip that is right above the keyboard then you will be able to get to the screws that hold the lcd. Remove the power cord, remove the battery and look inside the battery compartment to see if there are screws in it. If so remove them because the might hold the strip above the keyboard.
Turn the laptop back over and pry the strip off gently because there might be a cable attached to it. Now you should be able to tighten the screws that makes the lcd lid movable.
May 04, 2012 | Sony VAIO VGN-AR730E/B Digital Studio...
The display system of the vaio notebook went dim then finally died out.what is the possible problem and solution to the same
Hi akeyow..
Sounds like you have either a bad lcd screen or a bad lcd inverter.
To check to see if the screen is bad, connect the notebook to an external monitor that you know is working...if it works the you will have to replace the lcd screen.
If it doesn't work then the internal lcd inverter, will need replacement.
Both replacements take a better than average skill to replace, maybe best left to the pros...or sometimes you can check out YouTube and some people show you how to do it.
Please take time to rate me
Sony lcd replacement:
http://www.screentekinc.com/Sony_Vaio_VGN-CS_Series_VGN-CS215J~W--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is a link to the YouTube webpage for replacement, could not find your model, but I am sure you could use some of the info to replace what you have...
http://www.youtube.com/results?search_query=Sony+VAIO+VGN-CS215J%2FW+screen+replacement&aq=f
Lcd replacement, lcd inverter replacement
Aug 22, 2011 | Sony VAIO VGN-CS215J/W Notebook
My laptop lcd have straight line in upper and lower at the start tab, and my lcd is blinking and cause it to hang every seconds, and when i connect to other monitor its okey theres nothing problem, please...
strip of your laptop lcd is not properly connected with the board or it got crashed.
take it to some professtional to check and ask him to check strip of lid.
Jun 28, 2011 | Sony VAIO VGN-C210E Notebook
How can I replace my defective HDD on my Sony laptop model VGN-SR210J
remove the screws for HDD from the back side of laptop... remove the screws that holds the HDD...
replace the old HDD with new HDD...
place the screws back and close the lid...
Feb 06, 2011 | Sony VAIO VGN-SR210J/B 13.3-Inch Laptop...
Screen has a one inch white line down the middle
possibly a bad LCD screen, no other solution aside from having the LCD replaced.
Feb 18, 2010 | Sony VAIO VGN-N130G/W Notebook
Sony vgn-ar250g the light is lid but the operation system won't s
It is because your memory is faulty so try to replace the RAM ..
Nov 05, 2009 | Sony VAIO VGN-AR250G PC Notebook
Sony VAIO VGN-AR630E Notebook Logo
228 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
