Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
PC boots but the screen is blank
My OS is WinXP Home Edition. IIt boots up normally but the screen is blank. What is the problem?
What should I do?
    President:
  • 1,996 Answers
Please have a look at this article. (and this one.)
I'd begin by pressing F8 while it boots and see if you can start last known good configuration or safe mode. If so, you may want to use your system restore to restore to a previous date that worked. And I would recommend following these protocols to scan for malware that may have gotten into the works somehow. Do this before you shut it down again, but run mbam from normal mode if possible.
If that doesn't work, you'll need your recovery disks to run the recovery console, and I'd recommend you run chkdsk c: /r to check your hard drive for corrupt files that are preventing it from booting. See instructions here and here. and here.
Here are some links to other helpful articles that deal with startup problems, and may help you to diagnose the cause.
You might also want to take a look at the Event Viewer and see if there are errors or warnings there that indicate a problem. Instructions to do that here.
Finally, this startup troubleshooter helps explain how to check for unseated ram and other hardware problems that could be contributing to the failure to boot.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
    Novelist:
  • 81 Answers
If you are turning on your computer and it boots to blank screen normally with a blinking cursor this is an indicator of a Master Boot Record issue. If you drive has become damaged or corrupted this can occur and as a result you will not be able to boot into your OS. You should obtain a copy of your hard drive manufacturer's diagnostics disc and test your drive. If your drive fails the test you will have to try replace it and reload your OS, If your drive passes the diagnostics test you should attempt to boot off of your Windows XP install disc and select the repair option. This can sometimes can repair the corruption and allow you to boot XP again. However, if your drive passes the hardware diagnostics, but fails to be repaired by the XP install media I advise you backup your data and reinstall the OS. You can backup your data by removing the drive and installing it as a slave drive in another computer or connected it to a USB drive reader.
Posted on Jul 24, 2009
When i start my laptop the system doesnt boot and gets stuck after main memory check page. I need a help on this. When ever i power on system doesnt read os to laod at all and shows blank...
You will need a WinXP CD....
insert the CD and re-boot...
if boot seq is not set to boot from CD change it
restart PC...immediatly press either (F1, F2, Del) key to got to BIOS menu....
look for boot seq,
change the 1st boot dev to CD/DVd rom
save and exit BIOS menu
re-boot....
let the PC boot from CD
follow on screen inst...to reapir the OS or reinstall OS
for more info
got to my site
www.sureshayyar.110mb.com
Reg
Kris
May 08, 2011 | Fujitsu AMILO PC Laptops
I have formatted the boot partition (winXP Prof pre -installed) and installed Windows 7 and after BIOs the screen goes blank
Hi pratimpal
You should have directly upgraded to W7 instead of formatting . Try reinstalling Windows 7 on the same partition , it should work . Otherwise , back up all data on an external device , format entire drive while installing W7 and create new partitions afterwards with http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html
Best regards ,
fanaudi .
May 03, 2011 | Computers & Internet
Monitor is blank on Dell 3100
try starting in safe mode and then change setting
Mar 13, 2009 | Dell Dimension 3100 PC Desktop
Startup & Restart Problems on Athlon XP3000+/Abit KD7-G/WinXP
I believe your hard drive is dying. Buy another and get backup software like image home or reload everything from the install disks..
Jan 05, 2009 | Computers & Internet
XP RESTARTS
this is caused because a file of your pc has become corrupt and your XP needs to be reinstalled.
Dec 31, 2008 | Microsoft Windows Xp Home Edition Sp2...
Wont boot into safe mode, hold up at loading driver acpi multiprocessor PC
do you have XP bootable CD? If yes goto BIOS settings and select primary booting device CD Drive and save settings and exit. After restarting your system You will be asked to press any key for installing the OS.
Oct 29, 2008 | Microsoft Windows XP Home Edition
Windows XP Pro installed but computer boots to Home Edition
It sure is possible.
I would take it back to them and demand that WINXP Pro is put back in there and it boot correctly
They saved about 50 bucks putting in WINXP Home.
Sounds like a bunch of rookies trying to pull a fast one.
Nov 13, 2007 | Microsoft Windows XP Professional for PC
Installing windows xp
Try first  to use hiden boot cd.With it u can see all files on hdd.When u see winxp files just delte.But i will not take responsibility couse sometimes xp wont boot up...
But i recomneded you to save all your data and format your pc.Make sure that the partition cd must be deltet befor u contiuing with formating ur pc like in this pics:
http://www.imagehost.ro/pict/3003390347268b3728923.jpg
Oct 29, 2007 | Microsoft Windows XP Home Edition
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
127 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
