Back to:
Tags:
Refrigerators
Generic problem for all Refrigerators
Frost on icemaker door (by 4 users)
posted by enel on Nov 21, 2007
My Galaxy 55622 side by side refrigerator freezer has recently started building up frost on the "trapdoor" that transfers ice from the bin to the dispenser. The frost is also on a small section of the ice bin directly in line with the dispenser. The ice comes out slowly and in clumps, sometimes with frost. The ice bin is not on the door.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by fluglotse1, posted on Oct 17, 2008
Ice forms around the chute where the cubes come out.
Comment by RickColley, posted on Dec 16, 2007
Exact same problem here. Can the flapper door in the ice chute be replaced?
Thanks
Comment by Guest, posted on Nov 23, 2007
Ditto! Thought the door wasn't closing well. Cleaned it off, made sure the door was closing well & voila the frost came back! So here we are...and glad to see
it's not too uncommon & there's a possible solution!
Thanks!!!
Best Solution
posted on Nov 21, 2007
Helpful (85)
watugot
Rank:Guru Guru
Rating: 94%, 321 votes
Most likely the ice door is not closing properly.
Clean out the ice chute and look down it from the inside while you shine a flashlite up from the outside. If you see light around the door then it needs to be replaced or something is wrong with the mechanism.
Post back and let me know what you find.
Comment by watugot, posted on Nov 24, 2007
Just wanting to follow up on your problem and see what you have found. If the ice chute door is closing properly when you check it, then either there are times when it does not, or there is air leakage coming around the freezer door liner at the chute.
Thanks/Mike
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Frost on icemaker door:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
GE (PSS26MSRSS) Side by Side Refrigerator
water leak on the floor , and no ice water flow after...
Kenmore 62232 / 62234 / 62239 Bottom...
Vegetables freeze in the winter and I don't know which way...
Frigidaire FRS23R4C Side by Side...
Initially the fridge got cold to about 2 degrees C. Now...
Frigidaire Gallery Series GLHS269ZDB 36"...
No power to dishwaser, won't start. I checked fusebox, not...
Sub-Zero 650 / O Bottom Freezer...
Outside air (humidity) is causing condensation in my...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
