Question about LG Shine KE970 Cellular Phone
Backlight is screwed up
Ok the backlight wont turn on when i open up the phone, and when i close it partially it will, but then i let it stay fully open after wards, and then it will stay on for about 30 seconds, and it goes back off again, it is pissing me off. the light wont turn on no matter what, unless i flip it partially closed again.
  • 1 more comment
  • Robert P. Jul 25, 2009
    No you dont get it though, i can see its the backlight, not the lcd. i can see the screen in the light at a certain angle.
    YOU DONT GET IT! ITS THE BACKLIGHT! I CAN SEE THE SCREEN IN THE LIGHT! SORRY BUT IM PRETTY PISSED! CUZ WITH THIS PHONE ITS PROBLEM AFTER PROBLEM! FIRST THE CAMERA! THEN THE SPEAKER! THEN THE BACKLIGHT! THEN THE OK BUTTON! AND THEN THE BACK BUTTON! AND THEN IT WAS CREAKING WHEN I HIT CERTAIN BUTTONS!
    Ok found another thing here. it works if its plugged in, but the battery is out. once the battery is in, it stops the backlight, the front light. it stops everything. is this a loose connection in the wiring inside the phone? its hard to explain, but when i plug it in and its got no battery in it, the screens all work perfectly. once the battery is in, it stops.
  • 87 Answers
There is a short in it this is typical of flip phones. If your savy enough order a replacement lcd and get your self a T-set (screw drivers) for phones
Posted on Jul 24, 2009
Can i shut off the back light and or dim the
To change the backlight setting:
1.Press Menu/Ok >Settings >Display >Light Control > Backlight Control.
2.Select how long the backlight should stay on.(If you
choose Flip Open ,the backlight stays on as long as the
phone is open.)
3.Press Menu/Ok .
Thank you for using Fixya
Oct 08, 2009 | Motorola Mobility ic502 Cellular Phone
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
May 19, 2009 | Acer Aspire 5315 Notebook
I was chaging setting and I turned of backlight
If its just the backlight then you can stay in a well lit area and look at the screen that way to change the setting, also you could try plugging it in to keep the backlight on.
May 19, 2009 | Nokia 1600 Cellular Phone
Dell e193FPc monitor
The backlight or inverter may be bad. With the monitor on and the room dark, hold a flashlight very close and shine it on the screen . If you can see the normal display the monitor is OK but the backlight or the inverter which provides proper voltage to the backlight has gone bad.
Nov 10, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Motorola RAZR V3 - Backlight
Try removing the battery for a few seconds then restart the phone. Other than that, it could be a defective switch on the phone that detects when it's closed. If it answers / hangsup when the opened or closed... the switch is good.
Geno
Mar 04, 2008 | Motorola Mobility RAZR V3
Broken backlight
if you open the v3 phone flip...you shall see 4 rubbers...remove the rubbers with a very small flat bit screw driver then unscrew the 4 screws in the phone then use the small flat bit onc more to open the phone cover, then remove the silver button on each side of the phone, unclip the cable leading to the camera and also the clip connecting to the lcd once those are removed then replace the old screen with the new one.
Dec 22, 2007 | Motorola Mobility RAZR V3
BACKLIGHT STILL ON
How wet did it get? Was it submerged? The backlight would normally shut off after a short idle period or when you close the cover. If it is staying on all the time after water damage then there is still water in a component (like a capacitor) or corrosion that has opened or shorted a circuit path somewhere confusing the phone. There is a good chance that corrosion will become worse and do more damage. New problems could arise any time in the next few days or few years. If this were my phone I would disassemble it and clean it with rubbing alcohol, toothbrush, and air duster but there is some risk even for someone experienced. Also, microphones can be damaged by fluids including rubbing alcohol.
Jul 08, 2007 | Pantech C300 Cellular Phone
LG Shine KE970 Cellular Phone Logo
167 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
