LG washer not working
I own a LG washer , which when turned on fills with water and than spins couple of times and stops. On the electronic dash board it shows LE. What does LE mean and what do you thing is wrong with the washer.
  • 1,543 Answers
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Jul 24, 2009
Lg top load washer keeps filling and has to be manually stopped but it will drain when put on the spin cycle.
HI,
From your description, it sounds like there may be a problem with the inlet water solenoid valve(s). They can stick after several years of use. The se valves are located in the machine, just inside where you connect the water hoses.
Jul 25, 2015 | LG Washing Machines
LG front load washer continues to fill with water after spin cycle
Bad water valve or main board. the water valve closes when it stops receiving voltage from main board. If it's not closing then valve is bad.
Apr 07, 2014 | LG Washing Machines
IE code was displayed once. washer will not stop filling or spinning, clock freezes one minute past start up for wash cycle and while washer fills fast and in less than 5 minutes the washer does not stop...
The fault you have is a faulty inlet valve or possibly an electronic controller fault, you need to check with a multi meter if the inlet solenoid is always getting power or if there is constant power, (take care as this is mains power, if in doubt pay a professional to test) if the power stops but the water keeps flowing this is a relatively easy fix with a replacement inlet solenoid, if they fail the water pressure can hold them open and the machine will keep filling.
If there is always power to the solenoid then you have a faulty electronic control board.
May 14, 2017 | LG Washing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Dec 26, 2008 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
