Question about Mad Catz Bluetooth Headset for PlayStation 3
The bluetooth headset works fine until I start the match on Call of Duty 4 and then when the match is over it works again.
  • 21 Answers
Xxxxxxx
Posted on Jul 23, 2009
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Jan 20, 2011 | Jabra Stone Bluetooth Headset
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
How do i pair my H700 MOTORAL bluetooth to my verizon cell phone?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Im trying to pair my verizon cell phone to my motoral headset
6) You will be required to enter in a pass code which is standard ‘0000’.
Hope this helps
Chris (ziraffa)
Bluetooth pairing
Try the following:
a) Options->Bluetooth->Enable Bluetooth
b) switched on the Moto headset (blue light blinking)
c) options->bluetooth->add device
d) searching for devices....---> here it should find the headset and pair....
If it does not work do the following
After doing the above, do the following:
e). Start the headset. Start with the headset powered off, and hold the Call button for 10 seconds or so, until the light stays on. (Initially, the light will flash a few times before getting steady.) If the light is flashing, or if the light starts flashing anytime during steps f) through g), the headset is not in pairing mode, and this step (step e) must be repeated, again starting with headset powered off.
Select the Headset:
f.) Go back to phone, and select "[Look for Devices]." The phone starts searching for Bluetooth devices.
g). Once phone is finished searching, you get a list of one or more devices under the heading "Scan Results." Select the headset.
h). The next screen will read "Bond With ..headset." Select "Yes."
i). The next screen will be "Enter Bluetooth Passkey." Enter 0000 and select "OK." A screen will confirm pairing and connection. When the pairing is complete, the light on the headset will flash.
Sep 13, 2008 | Cell Phones
Connecting bluetooth to blackberry
Hi. You didn't say which Blackberry you have. I'll assume you know who to open "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your Blackberry.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your Blackberry.
Again open "Options"
"Bluetooth"
Open the Bluetooth menu.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Hope that helps!
May 25, 2008 | Plantronics Bluetooth Headset 610 Wireless...
Bluetooth issue
I dont know what you mean with get it to work but if you got problem matching with your phone the only thing you have to do is..press the on button until a red ligth apear this will send a signal to your phone that most be in bluetooth serching mode and that is, the code is "0000".....good luck and rate this
Sep 09, 2007 | Plantronics - Bluetooth Headset Plus Base...
Mad Catz Bluetooth Headset for PlayStation 3 Logo
108 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
William Wurtinger
John mullen
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
