Question about RCA Televison & Video
The power light keeps going out and can't reset. I pull plug and wait 30 seconds replug back in and power doesn't come back on, I do this seversal times finally tv resets and works for a few hours then goes back off again. I 'm thinking possibly in the power cord. TV is only 2 years old.
  • 21 Answers
Vvgfxcbfbvfd
Posted on Jul 23, 2009
Blinking lights???
With the unit plugged in and on, push the reset button for 30 seconds, and while holding the reset button down, pull the power supply plug out of the unit and keep the reset button down another 30 seconds, and THEN (still holding the reset button down) plug the power supply plug back into it and keep the button down for another 30 seconds.
That's a "30/30/30 Reset", and it should boot up fully reset.
Jul 20, 2014 | Linksys E2000UK) Wireless Router
The wireless light will not come on belkin router
Try pulling the power cable for 15 seconds on the modem, then plug it back up and then wait for all of the lights to come back on. Then pull the power cable on the router for 15 seconds, plug it back up. Also you have a reset switch on the back of the router that may help if the power cycling doesn't work. Hope this helps fix your problem-good luck...
Mar 14, 2012 | Belkin F5D8236-4 Router
Blinking power LED linksys
If the power light is blinking then you can try to reset the router.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Unplug the power and plug it back in. Wait for 30 seconds.
Check the status of power light on the router.
Jan 02, 2012 | Linksys Computers & Internet
Doesn't print the whole page
Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Oct 21, 2011 | Lexmark All-in-One Printer with PictBridge
How do I disconnect and reconnect my modem?
This should be as easy as pulling the plug from the wall, waiting 30 seconds or so, and then plugging it back in.
Mar 18, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have the Linksys Wireless-G WRT54GS Router and when i plug it into my modem, no lights come on, besides the power light which was already lit. I've tried resetting it (holding the reset button for 30...
There is another way to reset the router called hard reset..
you need to hold down the reset button for 45 seconds while its turned ON and don't let it go.
After first 15 seconds, take the power cable out but still keep holding down the reset.
After second 15 seconds, insert the power cable back in but still keep holding down reset.
After last 15 seconds, release reset and turn off the router for 30 seconds.
0-15 = Power ON, Reset button Pressed in
15-30= Power OFF, Reset still Pressed in
30-45= Power ON, Reset still Pressed in
If it still doesn't work then you got a bad router, can't be fixed. :-(
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
How do i reset my hp jetdirect 170x
Unplug the power to the HP Jetdirect 170x, press and hold the test button. while pressing the test button, plug the power cord back into the device and continue holding the test button for another 5 seconds.
This will reset the device.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf
page 5-64
Aug 11, 2009 | HP Jetdirect 170x Print Server
Reset hp2800
Hard Reset
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds then replug the power cable to the wall out let and then to the printer.
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the power button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the power button..
Aug 11, 2009 | HP Business InkJet 2800 Printer
Ink carts are full. cannot get to reset w/o the ! pt flashing. HP J3680
Hard Reset
Power Drain
Partial Reset
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the # and the number 3 button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the buttons..
Aug 11, 2009 | HP J3680 Officejet All In One Printer
Test light does not stop flashing
Hi Michael,
If the router has test light continously flashing then tha indicates hardware failure with the router. Try resetting the router using steps below:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. Press it and hold it from 30 seconds and after 30 seconds without releasing the reset button take out the power cable from the router and wait for 20 seconds. After 20 seconds, without releasing the reset button plug the power cable back to the router and keep holding the reset button for another 30 seconds. Now, release the button and take out the power cable wait for 5 seconds then plug it back.
If the issue persists, then it is time for you to purchase a new router.
Rate it, if it helps.
Jun 26, 2009 | NetGear MR314 802.11b
Televison & Video Logo
59 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
