Question about Haier HPAC99ER Air Conditioner
LEAKING WATER EVEN AFTER DRAINING THROUGH THE BACK HOSE. AFTER USING FOR ABOUT 8 HRS, WATER STARTS TO LEAK AT THE BACK THEN IT STOPS WORKING AND RED LITE FLASHES ON THE ON/OFF BUTTON. IT LOOKS LIKE WATER IS NOT EVAPORATING LIKE IT USE TO. I DRAIN IT THROUGH THE LITTLE HOSE AT THE BOTTOM ON THE REAR AND START ALL OVER AGAIN.
  • 37 Answers
Being that I am the owner of a Haier 12000 BTU portable A/C unit with the same flipping problem & having a husband that works as a refrigeration tech with plenty of experience with A/C units of all types, we have come to the conclusion that the evaporation pans they put into these portable units are either too small or faulty! The best advice I can offer you if you are out of warranty is to raise the unit onto a sturdy & level base (you can use wood planks if nothing else can be found) & attach a hose to the plug (open of course) & run the hose into a bucket. Sadly, I was unaware of how bad our situation was until my husband told me that it is "raining" in our dining room! We'll now have to rip up carpeting (only 5 years old), rip up the old vinyl flooring to check the sub floor & if that's too bad off, we'll have to replace it, then cut out the sheetrock of the ceiling, treat for black mold before it happens (because it will, wet wood & sheetrock make a lovely sort of place for it to grow exponentially!) then rebuild the ceiling! I hope you got help before my answer & good luck!
Posted on Aug 28, 2009
  • 21 Answers
Why the heck did u get it wet
Posted on Jul 23, 2009
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Stopped during 30 min cycle. not pumping water away. could be pump. how do i get to pump?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Jul 08, 2011 | Dishwashers
Water leaking on inside - top shelves
The drain for the freezer is clogged. Unplug the frige and let it defrost. Pull the cover from the bottom front and note the drain pan. water should start draining into pan as the freezer defrosts. If Not the drain may be blocked. To access the drain remove icemaker then rear panel of freezer carefully, unplugging fan and ground wire. Look for drain in the middle under the coils. Look on outside back for the drain hose, this will help you locate the drain. Clear the drain of ice using hot water. You will hear it drain down the drain hose to the pan below.
Mar 29, 2010 | Whirlpool Refrigerators
Leaks water out of bottom
hi friend,
Evidently you have reason to believe your washer is leaking. Probably there is water on the floor near the machine. Fine, then the first thing is some detective work. with an absorbent hand towel begin to inspect the areas where water enter or leave the washer. Those places are: 1. the hot and cold water inlet hoses located in the back and top of the machine and 2. the washer drain line, located in the back and bottom of the machine.
  • Step 2 One at a time, dry both ends of the hot and cold water hoses. watch for water to bead up. Water may be leaking from more than one place so don't stop with the first leak you find. Inspect all four possible connections and the hose itself. If there is a leak at a hose connection it's an easy fix. shut off the water supply of the leaking hose, unscrew the hose where it leaks and wrap Teflon tape clockwise around the threaded or male part of the connection. inspect the flat rubber washer in the female part of the connection. replace if it seems very worn. re-tighten the connection, dry and turn the water back on. check for the leak to return. If the leak in somewhere on the hose itself you will need to buy a new hose. Hot and cold water hoses are marked.
  • Step 3washingmachine3_thumb.jpg Next we need to check the hose where water drains from the washer. It comes from the washer near the floor level and usually inserts a male into the female of the washer hole. It then moves to the drain leaving the house. Again, dry the entire hose. Then you will have to run the washer. Use flashlight and inspection mirror to help you look for a leak during the draining process. If it leaks at the connection to the washer try reinserting and tightening the retaining screws. There usually are no threads to wrap. If that doesn't fix the leak or if you find a leak in the hose itself you will need to replace it.
  • Step 4 If you still have a leak under the washer it is probably in the drain hose between the drain pump and the outside hose or the short hose between the tub and the drain pump. This may be getting out of your level of competence. But if you want to be a Renaissance Man, give it a try.
    Unplug the machine. Now you need access to the bottom of the machine. depending on your brand you may be able to 1)remove the front by inserting a painters scraper and prying the spring snaps up, 2)remove the back by taking out screws and the rear plate or 3)you may have to go in through the bottom. With help tip it over on it's side. of course the machine will need to be empty of clothes and water as it's heavy enough already.
  • Step 5 However you access the inside bottom of the machine you will see a rubber hose coming down from the tub to a small electric drain pump then a plastic line will leave the pump and go to the back of the machine where it will meet up with the drain line you inspected in step 2. With your inspection mirror and flashlight look for water to indicate a leak. These lines are often held on by metal springs and can be moved or adjusted with open jaw pliers. If you find one of these hoses damaged take it off and bring it with you to your appliance store for a replacement.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • take digital photos before you remove any part. if you get confused you can use it as reference
    • don't work on the inside of the washer with it plugged in.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 24, 2009 | Maytag Washing Machines
    Old admiral clothes washer leaks at front
    Troubleshooting Water Leaks
    Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
    Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
    Step 1: Check the lid seal. If faulty, replace with a new gasket.
    Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
    Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
    Step 4: Check the drain hoses. Tighten connections or replace hoses.
    Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
    Step 6: Check the splash guard. Tighten connections or replace.
    Step 7: Check any plastic valve. Tighten connections or replace.
    Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
    Step 9: Check the water pump, using the procedures that follow.
    Aug 25, 2009 | Maytag PAV2300 Top Load Washer
    Im having a problem with my 2003 Chevy Malibu leaking coolant. What do I do? What do I check? I have no idea where its coming from. I can drive and when I park the car it starts to pour out coolant. I took...
    actually it is not good idea to replace your coolant by water only you shoul full your coolant system 50/50 mixture coolant and water because coolant has uniqe smell and color so easier to identified leaks.
    first check your oil condition and coolant reservior for any coolont oil mixture for figure out head gaskets condition if you have any oil coolant mixture in oil or coolant you have a blown head gaskets this will send you to mechanic if everthing looks clear then go front driver side bottom of radiator and open the drain **** (make sure car is cool and put container under because coolant is toxic and mess up your drive way )open reservior tab too and drain all the water close back drain **** probably your vehicle prefer dexcool(red color)
    fill 3 qt dexcool then water or just buy ready mix run the engine with reservior tab open and check coolont level add more if necesery suquize collont hoses for air inside when engine start hit up close reservior tab. on passanger side front of the engine has a coolant drain plug open with number 8 wrench untill you see the coolant come out( bleed the system for air) make this several times turn on your heat too and bleed again and watch your upper and lover hoses for any visible leaks fallow small coolant lines like under throttle body check thermostat housing under throttle body on 3.4l engines check under radiator if your pressure cab dosen't look good get a new pressure cab .shut of the car and check for leaks once you find out where is leak from easy to fix it.
    Jul 07, 2009 | 2003 Chevrolet Malibu
    Water Leaking
    HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
    Oct 14, 2008 | Frigidaire FRS26R4C Side by Side...
    GE Top load washer.
    Hello rschneeweis
    Welcome,
    Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
    Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
    Let me know if you found it and how you do.
    Huuum
    Please remember to leave a rating
    Oct 04, 2008 | GE WBSR3140D Top Load Washer
    My GE 21.7 cf no-ffrost side by side keeps running, leaks water to the floor and warms up. Age unknown. What might be wrong?
    the drain must be plugged . defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
    clean and clear drain plug back in and it will work like a charm...
    please let me know
    Jul 21, 2008 | Refrigerators
    Dirty water
    YOU HAVE A LOT OF RUST IN YOUR ENGINE COMPARTMENT. INSIDE OF IT.
    WHAT ARE YOU USING ?? WATER OR COOLANT TO FLUSH IT ??
    WATER IS CREATING THE PROBLEM SO I RECOMMEND TO USE COOLANT .
    THE COLOR WILL STAY THE SAME BUT YOU WILL STOP RUST FROM CONTINUING GROWING.
    Jun 02, 2008 | 1989 Ford Taurus
    Haier HPAC99ER Air Conditioner Logo
    793 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Vincent Schnittert
    Vincent Schnittert
    Level 1 Expert
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
