SOURCE: Replacing Door Hinge
Before replacing the hinge, try to spray on it WD-40 or an equivalent and wait for awhile, it might solve your problem. In case it will not solved your problem and you need to replace the hinge, by removing machine's upper cover (open 2 screws on the back cover and then slide it out)you will have an access to it. Good luck !
SOURCE: Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
SOURCE: LG Bottom freezer refrigerator LRFD25850ST
You will have to buy a new board to solve it.
Sgt 48
SOURCE: LG Refrigerator model LFX25950SB
it means that the motor fan inside freezer the sends air to the ice maker is not communicating with mother board you have no ice right then you need either the motor fan or main board if you dont know howto trouble shoot you need a tech to come out
SOURCE: LG LRFD25850ST French Door Refrigerator -
Unplug ref for about 5 Min. If does not fix the board in the door may be at fault or the main board.
You may need a service call.
