Question about RCA RS2664 Shelf System
Open err 255
When i turn it on its on tuner then open err 255. other times it turns on then after a few seconds it turns off. no code just resets. dosnt anyone know how to fix this?
  • mikeweber339 Jul 23, 2009
    some times there is a code and sometimes not. it works better when there is a code cause at least then i can change the source and use it for other things. is there even a solution to the code open error 255? i have only seen problems with this and no solutions. with this many people having this problem there must be a solution. some one tell me what it is please.
  • 21 Answers
Are u sure its not the code
Posted on Jul 23, 2009
Dosnt turn off says on but if you press any button it just beeps
bad control board maybe u can reset the applaince? try turning to off position pull out knob then unplug for a couple minutes then plug back in then lift open and close lid slightly 6 times within 12 seconds - good luck
Jul 10, 2014 | Hotpoint Ultima WF860 Front Load Washer
Zen Vision M 30Gb Mp3 player wont turn on
remove the battery, if you let the battery connecters hit the terminal a few times it works a a manual reset it works with almost anything
Jul 20, 2009 | Creative Labs ZEN Vision:M Digital Media...
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Radio error on Acura
you need to take the neg (-) battery cable off to reset the radio. you can only enter the radio code 3 times incorrectly than it will lock up. i think you can pull the back up fuse from the under hood fuse box for 10 seconds and that will also reset it.
Dec 02, 2008 | 1997 Acura CL
Won't Star keeps flashing Pause and Err
that was just happening a few seconds ago with mine and i just tried pusing the control button and the options button at the same time for a few seconds... i reopened the door and pressed start again...it's running now... good luck
Apr 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
Blinking light mitsu ws-55515 rptv
if the set is shutting down it should blink a code. Try pushing in the menu and input buttons on the set both at the same time and hold them in for 8 seconds to see if the self diagnosis will falsh a two digit code. Let me know what happens
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Open error 255
pls check supply voltage to tuner circuit,since this is digital tuner check digital clock and data.if you dont have scope to check,may be you try with vom meter and check about 4.7v on both line.when you select tuner notice slight flicker on your metre which will give hint of clock and data present.
Dec 16, 2007 | RCA RS2664 Shelf System
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
RCA RS2664 Shelf System Logo
277 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
