Question about Brother SX-4000 Typewriter
Characters are off?
I found that I had accidentally hit the wheel with the letters on it. I'd type 1 2 3 and 4 5 6 would print. I pulled back the hammer and moved it by 3 spots and it corrected the problem.
  • 43 Answers
Change CASSETTE DAISY WHEEL
Posted on Aug 07, 2009
What can be the solution's, I am typing the letters on the keyboard and it is printing all different characters on the paper -- is there a command set that should be cleared?
First pull out printwheel and see if the "spokes" are even and straight, Second try a new wheel, and third, on this Brothers, when you turn it on the carrier has to go to the left and you will hear the wheel turn and cycle to the correct home spot. Some times there is a arm that comes out of the left side frame that loosens up and throws the time off, check for loose bracket on left side. But a new wheel may solve the problem Good Luck.
Jun 12, 2014 | Brother ML-100 Typewriter
Typing the wrong letters
First try opening and closing the top cover. If that does not reset the print wheel to the correct characters, check and make sure the correction tape is not interfering with the wheel as it spins. If that is not the case remove the print wheel and make sure non of the spokes are bent. If they are you can try bending them back to the right position or you may have to replace it.
Jan 17, 2012 | Brother GX-6750 Typewriter
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
I need tray 2 to be the default setting for this printer. It always reverts back to tray 1 everytime I try to print.
Paper Handling Issue -
Hit Menu
Arrow down to Paper Handling and hit the green check
hit the green arrow to go into Tray 1 size - arrow down to envlope #10 hit the green arrow to save
arrow down
hit the green arrow to go into Tray 1 type - arrow down to envlope hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 size - arrow down to letter/legal (depends on what your using) hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 type - arrow down to plain (assume that your using plain paper) hit the green arrow to save
also pull out the paper tray and confirm the guides (where you can adjust from letter to legal etc)
is set correctly.
That should take care of it unless the document you are tring to print is a different type of paper size.
Oct 19, 2010 | HP LaserJet P3005n Printer
ML 100 Brother - Standard
If the characters are showing up different than the ones you pushed then your wheel is probably bent. First, open the clear cover on your ml100. Second there is a black lever that you pull towards you. Next, you pull the wheel out and if any of the arms on it are bent than straighten them out, and make sure none of the arms are over lapping. Next, return the wheel, push the black lever back into place, close the clear cover and then hold down the code button and press the reset key (the "q" key). If that does not work then you need a new wheel. This is what just worked for me, I hope it helps.
Jul 31, 2008 | Brother ML-100 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Wheelwriter 3500 only printing top half of letters
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Mar 20, 2008 | IBM Wheelwriter 30 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Brother SX-4000 Typewriter Logo
170 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
