This is a phrase or saying but I'm really stuck with this. Can you help?
SOURCE: I need Electronic Catch Phrase game's manual
go to http://www.fgbradleys.com/rules/Electronic%20Catch%20Phrase.pdf
SOURCE: electronic catch phrase is repeating words - just purchased
I don't know if you ever received a solution to your problem, but you might try taking the batteries out and putting them back in again. If this doesn't resolve the problem, I would take the unit back to the store where you purchased it. If this helps, please give me an appropriate rating and thanks for using FixYa.
SOURCE: mac computer doesn't hear voice when using rosetta stone
I have windows, so I don't know if this will help, but I found that you have to make sure that the recording device is named "Microphone HS" or something with the word "microphone" in it. For some reason, rosetta stone does not recognize recording devices unless they have the word "microphone" somewhere in their name.... This is true for windows, I don't know if this is true in Mac. At least this may point you in the right direction. :)
SOURCE: "security key/pass phrase"
Yes, it will set it all back to factory defaults
to set the security again on the router
Support site for D-Link is here http://www.dlink.com/corporate/worldwideoffices/?redirect=/default.aspx
In principle:
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - http://192.168.0.1
Enter (admin) for the user name and also for the password.
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password
On the PC
Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7:
http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
http://www.tp-link.com/support/showfaq.asp?id=214
- delete the wireless profiles
Start> control Panel> classic view> network and sharing center> manage wireless networks
Delete the profiles
you will then have to enter the wireless security key for any networks you connect to
Wireless Profiles - XP
http://www.tp-link.com/support/showfaq.asp?id=186
- delete the preferred networks
start> control panel> network connections>
right click on the wireless connection listed wireless networks tab in the preferred network list
click on each one and - remove button
SOURCE: My television continues to display the phrase
Go to Menu - then channel - then memory channel - let the tv reconfigure the channels. You might need to unplug tv (the light to tv might still be on - press the on button to release the juice). Then plug tv back in. I did this and it worked.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
