Question edited for clarity.
Question moved from Washing Machines to a better category.
This appears to be an Australian machine and is unknown in North America. The is nothing on it apart from people selling them and no manual available.
Normally, you remove the top. Then you remove the macerator, the part with the teeth. Then finally the basket. You wipe out the machine with a wet cloth and put it back together again after washing rinsing and drying the removable parts. The machine itself is not washable.
if it is intermediate workings there is a micro switch that is a must so it wont turn on when your fingers are in it might have some junk in it clean your machine. look if the micro switch fell inside machine ?
to clarify- I was just starting out this morning, juicing some carrots and heard a pop (carrot chunk hitting the inside of the pulp cover) and the machine stalled.
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
it probably has developed a loos connection inside. Pressing on that part reconnects the loose connecion inside the machine. If you are someone with a good mechanical aptittude, you may open it and somehow make a hood connection again. The problem should be obvious, and straight forward to fix.
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION. IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON. IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
very easy to take apart. since all the skin and hard parts of fuits and veg. are shredded theybtend to stick and bunch up in the machine, sumtimes against blades.clean after every use inside and out
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked.
Hello Duane,
Your machine is equipped with a magnetic start system which will only allow
the machine to start when you have the screenholder all the way in place
just as you would have it to start juicing. If you do not have any parts on
the machine it will not start. Please assemble it again and give it a try.
If it still wont start call me at 209-369-2154 for further assistance.
Thank you
Carl
