Question about Grilling
Need a manual for A033141 smokey mountian smoker
  • 5 Answers
Please go to Weber.com and click on parts and support. Under manual and enter that serial number.
Posted on Mar 27, 2017
faunnna
SOURCE: Smokey mountian series propane smoker
http://www.weber.com/dealer/
That address should get you to a dealer. Whether they will have parts or not, I am not sure. The site does have a replacement parts tab, but it is under repair currently.
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: I need a manual for
Yes I do, what do you need to know?
contact me marite55@mail.pf
Posted on Jun 08, 2009
SOURCE: Need manual for Great Outdoors Gas Smoker
You can look under Landmann USA. They make the smokers now.
Posted on Sep 13, 2009
  • 86 Answers
SOURCE: Cleaning
easy off grill cleaner and don't forget to let dry and unplug the unit
Posted on Sep 21, 2009
walesarumi
  • 6993 Answers
SOURCE: need a owners manual for
The truth is that the user manual/instruction for your propane smoker is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of this unit via phone or e-mail and request for the instruction/user manual from them. They might give it to you or direct you to a dealer where you can get the instruction/user manual.
This is the best you can do to get the instruction/user manual you are requesting for. Go to the propane smoker's website, check "Contact Us" and you would see their e-mail and phone number.
Below are some instructions that may help you with your propane smoker;
Set Up the Tank
The first thing to do in using your propane smoker is to connect the propane tank to the smoker. Open its valve by turning it in a clockwise direction. Next, you need to locate the wood chip box. Fill the box with any wood that you prefer, like hickory, mesquite or oak.
The wood chips when lit produce a smoky flavor that is absorbed by the food in the propane smoker. Each type of wood produces its own distinct flavor. Remember to soak the wood chips for at least an hour before using them so that they do not burn quickly. Soaking the wood chips also helps to create more smoke inside the propane smoker.
Fill the Water Box
After filling the wood chip box, you need to fill up the water box of the propane smoker. It is usually located right above the wood chip box. You can fill the water box with water or with sand. You can leave it empty, but it is best filled with water because the evaporation during the cooking process keeps the food from getting dry and tough.
When cooking with a propane smoker, moisture is important. Keep adding water when the level in the box is low. To add more flavor to your food, you can also add spices and seasonings to the water.
Cooking Time
The propane smoker is almost ready. All that is left to do is turn on the smoker and adjust the temperature. Most models have a rotary dial that controls the level of temperature in the smoker. The temperature depends on the type of food that will be cooked.
You should use a higher temperature for thick slices of meat and a lower temperature for thin slices of meat or for vegetables. Once you see smoke coming out of the smoker, it is time to put in your meat or vegetables. Cooking time depends on the kind of food being cooked and the thickness of the meat being smoked.
I hope this helps.
Good luck.
Posted on Mar 10, 2011
Weber grand cafe heat
Some tips here
Weber com Support Help Grilling Tips
You can ask them for manual
Weber com Support Manuals
Some tips for smpking
Top Ten Tips for Smoking
The Best Setup for a Weber Smokey Mountain Barbecue Smoker and Other Bullet Shaped Charcoal Smokers
amazingribs com
Watch this video
Weber Grills Smoking on Your Smoker
May 24, 2015 | Weber Grilling
Master forge electric smoker will not heat up
Hi, smoker heaters can be found on amazon (sounds like you need new one), here: Amazon com Old Smokey Electric Smoker Replacement Heating Element. I hope this was helpful. regards
Dan
Apr 13, 2013 | Grilling
How do I use it?
I've been smoking for over 10 years and basically use the Weber Smokey Mountain. You need lots of practice to make good "Que" but once you get the basics under your belt you too can make some awesome barbecue. I can guide you to the Virtual Weber Smokey Mountain site to get the basics. Google " Virtual Bullet" Enjoy...Hank
May 19, 2010 | Char-Broil Charcoal Water Smoker 4654301
Cleaning
Spray it down with oven cleaner, let sit for a few minutes and rinse. If it has aluminum finish on outside don't let spray come in contact with finish make cause streaking but it will be clean. Also, being that the smoker is electric keep water away from heating element and controls.
Sep 21, 2009 | Old Smokey Electric Smoker
I need a regulator for a Great Outdoors - Smoker
gas regulator are gas regulators so go to a hard ware shop that sells BBQ /outdoor cooker equipment,
take yours along as a sample and get a new unit
Apr 25, 2017 | Grilling
I need the owners manual for the Redi Smoke electric smoker .It is the Redi Smok by Burkhead Manufacturing Co. The model number is 09899. It has 120V AC-1250watts
I might have one if its the same redi smoke that was made in Houston Texas about twenty years ago or so...wimberman
Jun 12, 2009 | Old Smokey Grilling
Company went out of business.
Dec 17, 2008 | Grilling
Oct 30, 2008 | Grilling
Grilling Logo
240 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
