Question about Samsung LE37B550A5 37 in. HD-Ready LCD TV
Hi, i have a 2.1 surround sound system which i run using the headphone socket in my samsung tv. i think the socket has broke as no sound comes out of my speaker when i plug it in. will i need to send the TV back for repairs? thanks
  • 82 Answers
Does the TV have audio out jacks? if so use a RCA to 1/8" stereo adapter and hook up the sound like that.
Posted on Jul 25, 2009
How do I connect my LG 32LD350 to a samsung HW-E350 sound bar? My tv does not have audio out jacks.
Sorry but you cannot do this with this tv.. You need hdmi 1.4 support and you only have 1.3 the only way i have heard of it being done is through the headphone socket to a 3.5 jack to the aux socket on the soundbar.... johnB
Feb 22, 2013 | Samsung HW-E350 Crystal Surround Air Track...
I have a Samsung LE40B650T2 - no sound direct from the TV
It sounds that the sound processing section [digital circuts] are working well, and the fault must be either to the speakers, settings or to analogue audio amplifier section. Make sure that the Mute function is OFF. If it is OFF, and still you do not get audio output by tV speakers, surely the fault must be to audio amplifier circuits, provided speakers are OK. If your TV has a headphone out socket, this socket should also checked for proper interconnection.
Jun 24, 2012 | Samsung LE40B650T2 40 in. Full HD Crystal...
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
How can i make the sound from my direct tv on my samsung widescreen come through my new samsung surround sound instead of the tv speaker
There should be red and white output jack sockets on the back of your TV. Just connect them, using the appropriate cables, to the TV input on your surround system. Once you get it working, remember to disable the tv speakers via the tv menu.
Sep 22, 2009 | Samsung Televison & Video
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Samsung LE37R888D LCD TV. No sound from the main speakers or Line out.
    This problem arises due to cross pin connection of the headphone socket.Mostly frequent use of the headphones result this situation (no sound via external speakers). Call any service man he will provide you the services at nominal charges. And if you can do it by yourself then approach to the headphone section and just adjust the headphone pin, This will solve the problem.
Thanks for using fixya.
May 21, 2009 | Samsung Televison & Video
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
No sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
Jan 24, 2009 | Samsung HT-Q100 System
Sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Nov 14, 2008 | Sony DAV-S400 System
Samsung LE37B550A5 37 in. HD-Ready LCD TV Logo
173 people viewed this question
Henry  Thomas
Henry Thomas
