No power Turn power on & display shows abot 7-8 secs then goes (power off).Wiring board? I bought used at a pawn shop about 9 yrs. ago.
  • dsstratton Jul 25, 2009
    hanks so very much!
  • 410 Answers
You usually will find bad solder connections on your 5v and 12v regulator IC,s in the power supply area.
Posted on Jul 25, 2009
Wont start, goes straight to cycle ended
have the program board check for failure
Jan 04, 2016 | Electrolux Washing Machines
Diagram abot wire harness
A wiring harness for the unit is most likely more than you would pay for a used unit at a pawn shop. Most sony receivers have the terminals labeled on the circuit board. If you are lucky, you can find a dead one at a stereo shop or repair shop near you. They didn't name them explode for nothing. Be careful. 25312832-wng3opgl1pug32fsc4t4fc4i-2-0.jpg
Dec 08, 2014 | Sony XPLOD CDX-GT200 CD Player
SP OFF mode?
if you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
Jan 29, 2014 | Kenwood KDC-MP235 CD Player
Pawn Shop deal for pawning an hp ProBook 4320s i3 laptop with windows 7 professional (used)
Flea bay will sell it. Working around 199 GBP to 250 GBP is the going price so a Pawn Shop will offer 1/3rd of the worst price. 60 GBP, if you are lucky.
Jan 05, 2014 | HEWLETT-PACKARD Computers & Internet
My air compress quit one day-tripped dedicated 20A breaker,25' of 10 ga wire thats worked fine for 9 yrs. Compr. is 9 yrs old -looks NEW gets little useage (20 hrs per year). Have taken apart mechanically;...
An ohm check doesn't tell you much about electrolytic capacitors except that they aren't shorted. One is a run capacitor (usually low uFd value) and the other is a start capacitor (large uFd). If either dried up, the power consumption should be reduced. Look at the cases of these units--they should not be bulged or leaking electrolyte. Check the rotation of the motor shaft by hand--it should spin freely. A worn out or seized bearing would produce these symptoms. Smell the motor to see if it has a burned odor. It's possible that the internal wiring has shorted. The 20 Amp circuit breaker could have failed--try moving the wiring to a similar breaker for a test. Hope some of this helps!
Jan 17, 2011 | Garden
Dear sir My sony vaio grx570 do not turn on properly. 1-if keep it up off for one day, it does not starts booting. but after 5 to 6 tries it get power on with AC power. Windows xp logo...
When you boot the machine, use the proper key to enter the BIOS and check the date and time. If it is wrong then the BIOS battery is bad. Replace it.
Mar 03, 2017 | Sony VAIO GRX550 Notebook
I just purchased the Sony CDX-SW200 from a pawn shop and noticed that it doesn't have a red wire attached to the wiring harness coming from the radio? Is this right? Is there supposed to be a red lead...
you bought it from a pawn shop --and you wired it up so you have some sort of wiring instructions -yes it could have the wrong harness for your application but the correct one for some other
May 01, 2017 | Sony CDX-SW200 AM/FM Compact Disc...
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Image Sensor Problem
Does the black line record on the tape? When you play back on a TV/Computer can you still see the black line. If you do that would be the image sensor.
Good luck!!
Feb 13, 2009 | JVC GR-D850 Mini DV Camcorder
50 people viewed this question
 Grubhead
Grubhead
