New batteries in remote. Held enter and menu, then power. nothing.
SOURCE: Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
SOURCE: CONSTANT BEEPING, EVEN WITH BATTERY
ups inverter mode is on but not output and continouous beep sound and then cannot reset.how is check the microcontroller ic.
SOURCE: wii remote not working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,
that explains step by step to fix the problem without any technical
knowledge. I hope this guide will solve your problem. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii
Problems Reference Fix Guide.
SOURCE: timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at www.tvrepairworld.com
