Question about Apple eMac G4 Desktop
APPLE MAC POWERBOOK G4 LAPTOP COMPUTER
HI,
I WAS WONDERING IF YOU COULD HELP ME? MY G4 COMPUTER WHEN I TURN IT ON IT SHOWS A GLOBE IN THE MIDDLE OF SCREEN THEN IT WILL CHANGE SCREENS TO THE FINDER SYNMBOL THEN SWITCH TO A ? IN THE MIDDLE OF A SMALL FILE. IT KEEPS SWOPING AND CHANGING BACK AND FORTH THEN WILL TURN OFF?????
WHATS THE DEAL WITH THIS?
DO I NEED TO LOAD DRIVERS ON AGAIN AND IF SO WHERE CAN I DOWN LOAD THE DRIVERS FROM SO I CAN BURN ON TO A DISK AND THEN LOAD UP?
THANKS AND I HOPE YOU CAN CAN HELP ME ...
CHEERS DARREN
darrenpritchard9639@hotmail.com
  • Anonymous Dec 02, 2007
    Have the same problem, I have tried holding down the "c" key but I don't have the start up cd/dvd, or any of the drivers for this computer do you know where I can get these from for free if possible.....
    Thanks again for helping me with this small problem.
    Darren
Had the exact same problem The issue is with BAD RAM. Uninstall all third-party non-oem ram chips and see if it will boot up. (If all you have is non-oem, user-installed chips, then simply install one at a time until you find the one that is bad.
Posted on Feb 16, 2008
  • 79 Answers
It sounds like your system is trying to boot from a network.
Insert your installation CD/DVD restart your computer holding down the 'c' key, this will allow it to boot from the CD/DVD, you should be now able to select your start up drive, select it then either follow the prompts or restart again
Posted on Nov 21, 2007
I don't know how to connect an external modem to my PowerBook G4 12
You need an Apple modem.
https://www.google.co.uk/search?q=apple+usb+modem&espvd=2&source=lnms&tbm=shop&sa=X&ei=SyT2VN7mE9KXavCJgng&ved=0CAcQ_AUoAQ&biw=1920&bih=971
Jul 28, 2013 | Apple PowerBook G4 Mac Notebook
Everytime I login to my Mac PowerBook G4 the screen shows logging in and then after about 30 seconds it goes back to login screen
HELLO
FOR SOLVE THIS ..Starting your Mac in safe mode does the following: ... Start or restart your Mac, thenimmediately press and hold the Shift ... If your startup disk is encrypted with FileVault, you might be asked to log in twice: once to unlock the startup disk, ... If the issue comes back, you might have incompatible login items. 1 800 726 0294 Apple Support Number Mac Technical Support Help Apple Customer Support Number 1 800 726 0294 Mac Help USA https://plus.google.com/u/1/116937682228750782866 APPLE SUPPORT NUMBER
Sep 09, 2017 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple PowerBook G4 not coming out of sleep mode
the issue is bassically with Hard drive data cable.Still check the system by reinstalling the OS.or else replace the hdd data cable.the issue may get solve
Apr 13, 2010 | Apple PowerBook G4 Mac Notebook
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
How to format an apple power G4 notebook
When the computer is off, press the C in your keyboard then turn on your computer. After that computer will boot from CD.
Regards.
Jul 10, 2009 | Apple PowerBook G4 Mac Notebook
My powerbook G4 laptop screen will not come on it is totally black. help
You can open the computer up and see if the ribbon cable is connected firmly. Most likely the back light went out.
Jun 08, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 going to white screen only!!
Do you have any external harddrive attached to it? If so, remove it before restarting. Try to start it up in safe mode by holding the Shift button down at startup: http://support.apple.com/kb/HT1455
Mar 24, 2009 | Apple PowerBook G4 Mac Notebook
Apple laptop won't turn on
Try to boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot.
If so run disk utility from the cd and repair the disk as well as permissions.
If this is successful your computer "should" be repaired. If it still has problems booting, Use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Feb 28, 2009 | Apple PowerBook G4 Mac Notebook
Start up
Try rebooting into safe mode, then emptying your trash and restarting to normal operation. In safe mode, all internet is dissabled, so dont go trying to fire up the bluetooth or wi fi. The systme trashes unneccessary fonts and cache that can complicate the boot up.
If that does not remedy, try getting anothe rmacintosh running 10.3 or higher and a firewire cable. Boot your powerbook into TARGET DISK MODE and from the other mac go to UTILITIES and run permissions on your powerbook ( it should be on the left pane in DISK UTILITIES )
These are a few quick fixes, if they dont remedy the situation, keep me posted and try providing more info, like which version of osx, what you were downloading, and what apps were open when it was last functional.
Keep me posted.
Nov 19, 2007 | Apple PowerBook G4 Mac Notebook
Apple eMac G4 Desktop Logo
76 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
