Question about GE GLD4600NCS Built-in Dishwasher
Even clean dishes come out dirty
I have a Kenmore base model, 6yrs old. It fills, washes and drys with no apperent issues, maybe more vibration than before. The dishes come out all covered with tiny particles, even if they were clean to begin with. I have cleaned the trap and pulled it apart without finding anything interesting. I have been told that the expected life span is only 5yrs but this just seems like it wll have too simple of a solution. Any Ideas?
  • 67 Answers
Perhaps your soap is "stale". Rinse agent also helps.
Posted on Jul 24, 2009
Dishes are still dirty at the end of the cycle
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
My dishwasher is not quite 2yrs. old and has always worked great until now. Top rack cups and mugs still are dirty inside from coffee, lipstick, etc., glasses have spots and are cloudy, and silverware...
Welcome to FixYa,
Based on your description I`d suspect a plugged wash pump.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It is not really referring to the heating issue, or maybe even your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
When you`re finished run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Aug 19, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Hi, My dishwasher is about 6 years old and lately it is not properly washing the dishes. We've noticed that the glasses look foggy and the plates are sometimes not as clean as they used to be. Also usually...
Hi
If you are observing that the dishes are not clean, then you’ll need to follow certain steps to be sure where exactly the issue. First thing to check for is the detergent cup and spray arms. Check if the dishwasher’s spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps.
Dishes are left unclean when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. The water inlet valve if faulty will draw very little or no water. However, if you observe that water pressure is fine and there is no issue with the Fill valve then check whether the dishwasher is draining. If it’s not draining then see if the drain hose is plugged or clogged. If drain hose is fine and the dishwasher is still not draining then there is some issue with the drain pump or drain filter. To check this you’ll need to disassemble the dishwasher and trace back the drain hose to a pump, remove the drain hose from pump and clean the debris from the pump and filter. Make sure you have lots of towels as there would be a lot of water coming out from the pump.
Next thing to check if the dishwasher is draining and filling properly is water temperature. Water temperature should be between 120 and 140 F. If water is not hot enough then heating element has gone bad, to check the element you’ll need a multimeter. Use the multimeter and check if the Rx1 reading on the meter shows reading between 1200 (1.2K) ohms and 1500 (1.5K) ohms, if not the heating element has died.
Please post back if more information is required.
Daniel
Aug 07, 2010 | Kenmore Dishwashers
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
GE GLD4600NCS Built-in Dishwasher Logo
62 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
